Old 11-22-2002, 05:51 PM   #1
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
Default adjusting idle?
How can i adjust my idle? I just installed a tec II and was informed to raise my idle. Currently, it's idling at ~670 rpms, and would like to raise it up to ~850. I was told there's a screw on the TB that i turn to do this? I can't seem to find this.. anyone have pictures or anything?
thanks,
Vic
cRayZee is offline   Reply With Quote
Old 11-22-2002, 07:38 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I suggest you delete this post and instead ask in the Engine Management forum...
Old 11-22-2002, 07:52 PM   #3
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
i'm not asking how to tune the tec to change the idle. I was informed that there's some kind of screw on the Throttle body or something to raise the idle.
The stock ECU is still handling the idle, not the TEC. I just want the idle raised up a bit.
-vic
Old 11-22-2002, 09:50 PM   #4
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
I think you're looking for the Idle Air Control (IAC) valve. I can't say specifically where it is on a SOHC engine, but...
On my MY98 it's monted on the side of the TB by two screws, one will have white paint on it from the factory. The one with the paint is the adjusting point (note that hole is elongated). BTW, it's black w/ a light blue top and electrical leads.
If you move it too much you will throw a CEL.
****Mark the position of the screw with a scribe before you start so you know where to go back to JIC.
Albert is offline   Reply With Quote
Old 11-23-2002, 06:19 AM   #5
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
i don't think my car has that screw...
Also, the ecu is already throwing a CEL cuz the tec replaces the stock O2 sensor
-vic
Old 11-23-2002, 10:17 PM   #6
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
anyone...
Old 11-24-2002, 01:58 AM   #7
NicGordon
Member#: 24827
2008 Kia Spectra
Default I don't know but...
I'm not really sure....but here's a warning:
Don't adjust the "Do Not Touch" screw!
read here:
http://www.endwrench.com/pdf/fuel/DontTouchInfoF00.pdf
NicGordon is offline   Reply With Quote
Old 11-24-2002, 04:57 AM   #8
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
ok, I might've solved the stalling problem already... had to mess with the tec's tps voltage settings and sensitivity.
-vic
Old 11-24-2002, 03:29 PM   #9
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The idle is automatically controlled.
here's a pic of one of the throttle stop screws
here is the bottom stop screw.....
Don't touch either of these screws.
They are adjusted at the factory so that the TB flows a certain amount of air.
Idle is controlled via the IAC valve. When you adjust the screws you can take the IAC valve outside it's operating range and cause issues.
On the older IAC valves you can turn the electro-magnetic servo motor slightly, and it will bump the idle either up or down slightly. The ECU should leave it alone since it does not know the IAC was taken out of it's "calibrated" factory state.
The newer IAC valves on the TB itself.......I'm not 100% sure if there is something similar you can do or not.
However....bottom line.....really shouldn't have to adjust those things if everything else is ok......it sounds like you adjusted some stuff to get it working.
Legacy777 is offline   Reply With Quote
Adjusting idle and throttle? Jish Normally Aspirated Powertrain 5 03-21-2006 11:05 PM
Adjusting idle speed? Alan l. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-01-2005 10:25 AM
how to adjust idle ???? veightkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-07-2005 11:21 AM
Anyway to adjust idle speed? Topshelf Normally Aspirated Powertrain 6 11-23-2004 09:27 PM
Adjust Idle Speed Stock Ecu (supercharged) Joncas Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-16-2003 09:27 AM
