#1 |
Member#: 5275
Vehicle:2002 impreza WRX WR BLUE |
well got last night, did the install this morning..took it out last night with my brother before the install and again after the install this morning..seems to be a little more pull...very little noise increase before 3000rpm's.. but not loud be any means. spool up seems better with this intake compared to the injen i had for a couple months..and the BOV sound is more pronounced as well as the whistle from the turbo spool up...over all i would say a good mod to have....maybe the same for all short ram style intakes, but i can only saw compared to the two differnt ones i have had on the car with the same mods still....
#4 |
Member#: 5275
hard to say about how much difference there is between stock and the injen cai...mostly but dyno. but there is more air noise, and you can hear the turbo spooling more..i just think that after having the two different intakes that the blitz has a better throttle response...
#6 |
Member#: 5275
yes, the LM series is a cotton material. not the stainless your's is made of...i went this route because i heard of a couple CEL issues the old SUS setup had...all in all i like the LM series, still happy with it....
#8 |
Member#: 5275
www.vividracing.com.. talk to dan or rob...
#9 |
Member#: 26099
Vehicle:03 WRX silver |
have this intake. have had it on for oh, a month now.
keep getting cels (too lean) you guyz had any probs? stock exhaust maybe the problem also... just inquiring.. got this one for the same reason you guyz did.. NO CELS..hehehhe ~the wanderer~ |
#10 |
Member#: 5275
wanderer, sorry to hear about that. have you pulled the code to make sure what it is? i have had some CEL's but the dealer said its the same one for the cat because i have a full turbo back exhaust, but no CEL's from the intake.. you can try contacting blitz or maybe even where you bought it from.. good luck at let us know what happens..
#11 |
Member#: 26099
ya i've pulled the codes. alwayz the same one.. too lean
i've got an autoxray code scanner that i usually keep hooked up for monitoring.. want to get that single din box from england that reads everything.. but i like the intake. thought about playing around with some air redirection or something. maybe block off a little bit of it... or go back to the stock box and sti filter i have.. no biggy. i want real hp i get on my BIKE!! ![]() |
#12 |
Member#: 5275
wanderer, that's still does not seem right. even more so if you are running the stock exhaust. just an intake alone should only lean out the fuel very little... i mean i have a full turbo back exhaust, intake a MBC running right at 16psi but i just keep getting the CEL for the cat... might want to check out vishnuperformance or turboxs and ask for some more info... even post in the tech forum to see if you get any ideas for others... good luck either way
#14 |
Member#: 5275
no, i don't think it should either.. can not see why it would. but then every car i have modded was never like the subaru WRX either.. this car has taught me nothing makes sense
#17 |
Member#: 5275
no K&N style fitler.. i believe this filter requires a replacement.. i kow it comes all most completly apart to replace it.. blitz web site does not say anything about it that ican find.. anyone here know for sure? this is my first blitz intake so not 100% sure on this...
#18 |
Member Sales Rating: (12)
Member#: 16345
Vehicle:2003 WRX- Sold E60 BMW 545i |
noob question:
my sus type lm came with only a cone filter and soem metal adapter peices, no intake tubing "arm". Where am i supposed to mount the MAF sensor when i install it? |
#19 |
Member#: 5275
that's correct.. just remove your current MAF sensor and remount in the new metal MAF adapter that came with your kit. you should have also gotten a metal arm/support to hold the filter in place.. one end mounts to the back of the new MAF plate and the other with one of the old bolts from the stock air box.. any more questions PM or e-mail me..
| Thread Tools | |
| Display Modes | |
| Blitz LM intake and Blitz BOV for sale | plaiboi | MAIC Private Classifieds | 3 | 09-10-2006 03:47 PM |
| blitz bov and blitz lm intake | plaiboi | Engine/Power/Exhaust | 2 | 09-07-2006 04:48 AM |
| Blitz LM Intake - Short RAM | Jonny | Normally Aspirated Powertrain | 0 | 03-12-2004 11:35 AM |
| FS Local: Blitz LM Intake | BADWRX | Bay Area Impreza Club Forum -- BAIC | 0 | 04-03-2003 02:03 AM |
| Just installed Blitz LM intake | KIMUTAKU | Factory 2.0L Turbo Powertrain | 12 | 01-20-2003 11:10 PM |
