Old 11-24-2002, 03:07 PM   #1
Ultralight
Member#: 29366
1990 Miata
white & 2003 sonic yellow
Default Front rear camber differential with 24MM sway bar.
I have only a vague idea how much camber I can get out of stock struts but what is a good starting point for differential between the front and rear on the WRX? I'll be running double adjustables likely with a 24mm front bar and 215 Hoosiers.
Ultralight is offline   Reply With Quote
Old 11-24-2002, 03:17 PM   #2
IXLR8
Member#: 14570
'02 WRX
Default Re: Front rear camber differential with 24MM sway bar.
The short answer is not much.
There is no stock rear camber adjustment, and the max number I've seen posted for the front with just the stock bolts is 1.5 degrees negative (seems like there are more posts with about 1.3 degrees, which was all I was able to get).
Gotta go to plates for more in the front and at least aftermarket bolts for any adjustment in the rear (stock rear spec. is 1.3 degrees negative, or pretty close to that if I remember correctly).
IXLR8 is offline   Reply With Quote
Old 11-24-2002, 08:45 PM   #3
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Why are you running a 24mm front bar?
- Steve
zzyzx is offline   Reply With Quote
Old 11-25-2002, 01:04 AM   #4
Ultralight
Member#: 29366
1990 Miata
Steve, I am preparing a new WRX for an SCCA DS SOLO II campaign next year. I hope to speed up transition on the WRX and reduce rollunder of the front tires. From other threads, I suspect a 24mm is the biggest I can go without aquiring more push than I can dial out with bump adjustment in the rear. What I am looking for is a starting point for camber differential between front and rear. I will likely re-align a couple times through the year as I learn the car but it will speed things up to start with conventional wisdom. Any comments on toe would also be appreciated.
FS: (CA) Whiteline STI Front Rear 27mm/24mm Sway Bars Endlinks & Ingall Camber Bolts Drag-On Suspension/Brakes/Handling 5 08-05-2009 12:17 PM
Front and rear 24mm sway bars KB'izzle Private 'Wanted' Classifieds 1 05-29-2008 07:13 PM
WTB: Front 24mm Sway Bar jondl Private 'Wanted' Classifieds 0 10-17-2007 05:47 PM
Cusco 21mm Front & Rear Adj. 22-24mm Sway Bar WRX 02-03 winston0064 Suspension/Brakes/Handling 10 11-27-2006 03:28 PM
Whitline heavy duty rear 24mm sway bar mounts AChan10 Suspension/Brakes/Handling 2 10-02-2006 10:57 AM
