Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 11-24-2002, 09:36 PM   #1
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
Default So am I running too much boost?
After the dp install, I'm hitting about .12 mPA in third gear (don't know about fourth).
Do I need to crank the boost down a bit? Am I in any danger of damaging the engine?
Big_Hitter is offline   Reply With Quote
Old 11-25-2002, 01:36 AM   #2
WR-REX
Member#: 5250
2007 Tundra RCSB 5.7
what is that in psi?
After my dp install i was hitting 18psi and the car would freak out feel like I was hitting the brakes and the cel would come one. I hit that damn fuel cut like 4 times. As for damage my car is still running, but we will see, I finally got it retuned and it is fine now at 15psi. Oh btw make sure you carefully install the probe back into the dp, at cobb they told me some guy fried his cpu and unichip when he had it twisted funny and the wires touched. just a piece of advice.
WR-REX is offline   Reply With Quote
Old 11-25-2002, 01:51 AM   #3
LiquidIQ
Member#: 6408
2014 FiST 2004 MSM
Race Red & Velocity Red
That's about 18psi. You are going to hit fuel cut like WR-REX if you stomp on it. If you are running a unichip you need to get retuned. I think fuel cut is at 17psi, not positive though.
LiquidIQ is offline   Reply With Quote
Old 11-25-2002, 07:02 AM   #4
Big_Hitter
Member#: 10831
2009 FXT VF52/E85
I was pretty careful with the 02 sensor - I untwisted it when I put it back on.
I think I need to at least crank down the TXS ABC a bit to run less boost, or take the unichip off and get it remapped or both.
Old 11-25-2002, 08:57 AM   #5
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
Default Re: So am I running too much boost?
Whats the rest of your mods? My RT Spec sr30 peaks at .125 MPa. The danger is not just boost, the the temp of the charge being produced, the efficiency of the turbo and intercooler.
Sam2 is offline   Reply With Quote
Old 11-25-2002, 10:17 AM   #6
gmflex
Member#: 9796
2004 STI
Manual boost controllers are cranky this time of year due to the cold weather (dense air). I would turn it down a bit to be safe.
Jason
gmflex is offline   Reply With Quote
Old 11-25-2002, 10:25 AM   #7
glilly
Magic 8 ball says Ban
Member#: 7245
13 BRZ
08 Avalanche
I went through this same activity after my uppipe and downpipe install. I did, however, remap to the TXS Stage 2. I still have to mess around with the TXS ABC once ina while to be safe. (i'm running at 1.1mpa's at WOT in 4th & 5th)
Greg
glilly is offline   Reply With Quote
Old 11-25-2002, 08:18 PM   #8
Big_Hitter
Member#: 10831
2009 FXT VF52/E85
thx guys, I'll crank it down a bit until I can get it remapped or retuned.
Weird boost gauge readings or too much boost in the cold? Blown95ImpalaSS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-29-2005 07:15 PM
Am I expecting too much??? Virgil Engine Management & Tuning 0 09-30-2003 07:41 PM
Am I expecting too much? Brahmzy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-16-2003 03:21 PM
So am I running too much boost? Big_Hitter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-24-2002 10:03 PM
Boost Monkey + MBC cranked down = too much boost, help! Mephiska Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 06-24-2002 03:17 PM
