Old 11-24-2002, 09:59 PM   #1
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
Default So am I running too much boost?
I just installed a dp and now I'm hitting about .12 MPa in third gear (don't know about fourth).
Am I in danger of damaging the engine? Do I need to crank the boost down a bit?
Stock turbo and IC
thx
Big_Hitter is offline   Reply With Quote
Old 11-24-2002, 10:03 PM   #2
1GR8WRX
Member#: 18792
Default Seems like a lot...
the stock turbo isn't efficient at that level, although I've been running at around that for almost 1.5 years without any issues. If I converted it correctly, that's 17.4psi, which most people will argue isn't a good move with the stock system.
-Andrew
1GR8WRX is offline   Reply With Quote
Weird boost gauge readings or too much boost in the cold? Blown95ImpalaSS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-29-2005 07:15 PM
Am I expecting too much??? Virgil Engine Management & Tuning 0 09-30-2003 07:41 PM
Am I expecting too much? Brahmzy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-16-2003 03:21 PM
So am I running too much boost? Big_Hitter Texas Impreza Club Forum -- TXIC 7 11-25-2002 08:18 PM
Boost Monkey + MBC cranked down = too much boost, help! Mephiska Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 06-24-2002 03:17 PM
