Old 11-25-2002, 06:41 AM   #1
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
Default Whats involved in swapping a 2000 Intake manifold for a 1999?
Whats involved in swapping a 2000 Intake manifold for a 1999? What other models would work such as Forrester, RS and Outback? This way I get more injector choices right? Any other info would be great.
cpu77 is offline   Reply With Quote
Old 11-25-2002, 10:36 AM   #2
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
As long as it is an EJ25, they should all work. I do know that 2000+ models have some air recirculation unit on the manifold, can't remember the name, someone help me out here.
Graham
Graham is offline   Reply With Quote
Old 11-25-2002, 11:03 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, depending on whether or not you have to use the MAP sensor hole (and if there is one on the MY99 manifold since some do have them, supposedly), it should be a pretty direct swap. Injectors will need to be switched, though I think the rails will work ok. Everything else should swap over without much trouble, though you won't use the recirc stuff from the MY00 any more. Hope you don't plan on getting no CEL's from the evaporative system since there won't be a solenoid there any more.
Old 11-25-2002, 01:00 PM   #4
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
I have a LINK ECU. NO CEL So I just would like something that fits good the RC's are kinda shabby.
Old 11-25-2002, 02:36 PM   #5
kaos200
Member#: 2692
just leave the solenoid plugged in, no cel (for that anyways)
kaos200 is offline   Reply With Quote
Old 11-25-2002, 02:45 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Heh, thats a big piece to leave plugged in... maybe find out it's resistence and put a resistor on there instead?
<--- No worries here... Haltech says "CE-what?"
What is involved in machining an 05 STI knuckle for a WRX? FromageTheDog Brakes, Steering & Suspension 6 11-09-2009 07:47 PM
Swapping out the intake manifold and mod ?'s 07SlvrScooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 05-13-2009 01:02 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
FS in PA: Magnus intake manifold for WRX/STi phlegmon Private 'For Sale' Classifieds 15 12-04-2005 12:55 PM
2000 2.5rs Intake Manifold for sale RollingOnAll4 Private 'For Sale' Classifieds 2 09-29-2005 10:02 PM
