Old 11-25-2002, 07:02 PM   #1
impreza2002
Member#: 30428
1999 Impreza 2.5RS
RALLY BLUE
Default Need help to locate the wires!
Hi,
I have difficulty to locate the wires of the IAT (intake air temperature) sensor for my impreza'99 2.5RS. As far as I know, the IAT sensor is combined with the Mass Air Flow Sensor. And I just found four wires coming out from the plug of the Mass Air Flow Meter! The color of the wires are (coming out from the plug starting from left to right) red, red/blue, black, and yellow. Please help to find out which two are the wires for the IAT sensor. Thank you very much.
impreza2002 is offline   Reply With Quote
Old 11-25-2002, 07:51 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You didn't buy one of those kits on ebay that is supposed to give some huge HP increase by fooling the ECU by modifiying the IAT signal, did you? If you did don't install it, they don't work and may screw up your car.
If you're asking for a different reason then ignore this
Old 11-25-2002, 08:02 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Thats exactly what I was thinking too.
I dont think we even have this sensor. The Barrometric pressure sensor in the ECU is the closest thing I know of.
Old 11-25-2002, 09:11 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
MAP based cars have an IAT sensor......MAF based cars do not have one.
Legacy777 is offline   Reply With Quote
Old 11-26-2002, 02:28 AM   #5
impreza2002
Member#: 30428
1999 Impreza 2.5RS
RALLY BLUE
Isnt that the IAT sensor is built inside the MAF? If the MAF based cars do not have the IAT sensor, then how do these cars sense the temperature of the air coming from outside?
Old 11-26-2002, 08:47 AM   #6
Legacy777
Member#: 4800
They don't. That's the whole point. MAF units measure the mass or the amount of air going into the engine. Air temp will change the reading in the MAF's measurements. So any additional air temp sensor is not needed.
MAP system use pressure & other sensors, like air temp charge to determine the amount of air going into the engine.
Got a little problem with the speakers, needs help to pinpoint the problem. SilentShadow Car Audio, Video & Security 4 12-03-2006 09:34 PM
need help to connect the tach wire !! SYMSWRX Engine Management & Tuning 0 08-19-2004 04:48 PM
Need help to choose the right EngineManagment Roffa Engine Management & Tuning 1 07-21-2004 11:04 AM
Need help to change the oem light bulb 2002blue Electrical & Lighting 4 04-17-2003 01:27 PM
need help to make the best sleeper subyguy1995 Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-08-2002 02:00 AM
