Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 11-25-2002, 09:02 PM   #1
Hedge
Member#: 6958
2002 WRX Wagon
Question Tire replacement question
I run a set of Sumitomo HTR Z and one of them went flat and totalled yesterday. So I'm out shopping for something to fill its space. I know it's bad to use a different tire but my question is, given 17000 miles on the other 3 Sumitomos, would getting just one new tire kinda confuse the AWD system?
And what's gonna become of this new one when the rest retire? Or am I screwed and have to fork out $100 for a tire that'll last me 5000 miles *whining *
Hedge is offline   Reply With Quote
Old 11-25-2002, 09:26 PM   #2
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
At the very least you should get two new tires. I had Yokahama Parada Spec II's on my 18" prodrive rims, and my fronts wore out faster than my rears, so I swapped them front-to-rear. That shouldn't be a huge deal for an AWD car.
Having one tire significantly taller than all the other three though, is going to put a little stress on your drivetrain. I'm no mechanic so I can't say exactly what compnent to point you at, but it follows that if you have one tire rotating less than another (a taller, newer tire) then something mechanical will haveto compensate for that rotation.
The other thing that you will run into is that your car wont handle as predictably with one new tire on. that tire will have greater water-shedding capability than the others, and seeing as it would be newer, its tread-blocks would flex more so it wouldn't handle as well as the other three. In a car that is regularly driven at the limits of adhesion, that unpredictability could be a big problem.
If I was you, I'd buy four new tires. If you can't afford nice ones right now, get 4 equally worn used tires until you can afford some new ones. It will cost you a lot more than $400 if you get caught out and clip a guard-rail etc 'cause one tire gave you problems. Your tires are literally where the rubber meets the road. My philosophy is don't mess with your tires, pay for the good ones.
aussiebrydon is offline   Reply With Quote
Old 11-26-2002, 12:01 AM   #3
JohnBlaze74
Member#: 24929
08 SPEC.B DGM
Default try this
i work in the tire busness and i've done this before, just get two tires and have them moved to the front and put the best ones on the rear then your only spending around $200
JohnBlaze74 is offline   Reply With Quote
Old 11-26-2002, 12:21 AM   #4
SilverBlitzkreig
Member#: 19492
2002 WRX Wagon
Thats a bad idea. If your other tires tread depth is too far off in 32nds you can ruin your allwheel drive.Check your manual for the exact depth I beleive it is 3 32nds.And as far as putting the new tires anywhere they always go in the rear to prevent a loss of control situation as per DOT specs.
SilverBlitzkreig is offline   Reply With Quote
09 WRX Tire Replacement Question jpjester Newbies & FAQs 61 10-23-2009 11:50 AM
Single tire replacement question... Killgore Trout Tire & Wheel 1 10-14-2009 09:45 PM
RWD tire replacement question - paging Luke? sonicblue Off-Topic 20 10-23-2006 11:57 PM
Tire replacement question (AWD) AWD_n00b Tire & Wheel 7 07-11-2005 06:56 PM
Need to replace a blistered tire... (tread depth/single tire replacement question) reaubideux Tire & Wheel 3 11-05-2004 01:28 PM
