Old 11-26-2002, 12:05 AM   #1
zoomfactor
Member#: 30440
03 WRX
WR Blue
Default WRX in ESP?
To all you Auto-Xers... Am I crazy to consider prepping a WRX for ESP? I was thinking about all the v-8s - kinda David vs. Goliath. Or is STX the way to go? I used to run a stock '86 MR2, but I want to get at the WRX suspension while the car's still fresh.
Any feedback is appreciated.
jd
zoomfactor is offline   Reply With Quote
Old 11-26-2002, 07:58 AM   #2
KC
Member#: 442
16 SS
00 S2000
Default Re: WRX in ESP?
jd
It's possible... with the migration to SM recently. With the rules allowed in ESP, I don't know if the WRX has the capability to add the power to do it... but it would be fun. Mmmm stickies.
I'm using STX as a stepping stone to either SM or ESP in a couple years. I'd rather get the suspension and power sorted out in STX on cheaper street tires then once that's done, go to a season where the only cost will be the r-compounds every couple months.
--kC
KC is offline   Reply With Quote
Old 11-26-2002, 11:23 AM   #3
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
That's a hard choice....
If you don't have aspireations for the nationals, then ESP is pretty cool. The problem you will have is boost creep. When you have added the exhaust, fuel management, intake, intercooler, etc... you will overrun the stock boost management. But then again, properly tuned, you could use the boost spike to your advantage.
I have competed against nationally prepped ESP cars in my region. It was a humbling experiance
Regionally, I have done very well. I won twice at events where those mooostangs were traction impared I had nothing more swaybars and 17" wheels. (pre-STX)
I think ESP is possible, but not likely. The amount of money you would have to spend on turbo killing performance would be better spent on a SM car.
I agree with KC. If you get your car setup for STX, then SM is the next logical stepping stone.
ChrisW is offline   Reply With Quote
Old 11-26-2002, 01:33 PM   #4
Crosser
Member#: 18627
As was stated before, boost creep is the big problem. This is one of the factors that lead Fedja Jeleskovic to move from ESP to SM in his Talon. He did very well nationally, especially in the Pro Solo events in ESP. If you can control the creep, I think it would be a great ESP car.
Crosser is offline   Reply With Quote
Old 11-26-2002, 02:40 PM   #5
KC
Member#: 442
16 SS
00 S2000
That's not the only reason he went to SM. He was one of the reasons, if not the primary reason for the 'No update/backdate Turbo rule' when he replaced his T25 with the TD04 from the 1st gens. Some people REALLY didn't like that move... which at the time was legal.
So after a year with the 'T-2-small' (which actually has a quicker spool time) he went to SM because of the limitless possibilities in SM (or he hit the ceiling in ESP).
--kC
Fedja taught me all I needed to know to get me addicted.
Old 11-26-2002, 06:48 PM   #6
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
I used to autox a talon before the WRX. Dennis Gant said it best "boot creep is your friend" If you can get the boost creep under control, then it is possible to have a reliable daily driver with a 25psi boost spike at low rpm 2nd gear. That makes for a hell of a launch out past the apex
The problem with Street prepared in general is that the rules favor cars whos basic technology has not really changed for 30 years now. The WRX just does not respond the same way to what the SP rules allow and remain reliable enough to be a street driver.
Old 11-27-2002, 11:40 PM   #7
zoomfactor
Member#: 30440
03 WRX
WR Blue
Thanks for your feedback! Can any of you guys explain a little more about "boost creep". My mind is lost in a N/A world.
And by the way I love these little cold fronts taht make it down to FL. The car feels like it gains some nice HP in the 50 degree mornings.
Regards,
jd
McCanix ESP WRX in Drive Performance (aka Subaru) Magazine S1MPSONS Autocross 22 12-15-2009 03:56 PM
Cage in ESP Solo 2 Storm Racing Motorsports 9 09-30-2004 03:37 PM
STi Stays in ESP (for now) bcblues Motorsports 8 01-30-2004 05:23 PM
Do you believe in ESP, sťances, and 'teh other side'? Stroke Off-Topic 20 10-20-2003 03:17 PM
No WRX's in ESP at nationals? veloLexus Motorsports 10 09-12-2002 12:05 AM
