Old 11-26-2002, 01:33 AM   #1
Ryan24
Member#: 451
2000 Impreza 2.5RS
2008 Legacy GT Limited
Question Hella 4000's....which beam pattern to use?
I plan on buying a set of Hella 4000 Halogen (i wish i could afford the motorsport version but those things are $$$$$)
I was wondering what beam pattern to use
I compete in TSD's or Road Rallys and I am looking for a good beam pattern to use
the choices are
Euro Beam
Euro Beam with City Light
Pencil Beam
Cornering Beam
I'm leaning toward the cornering beam since that give a wide dispersment with light and also a long dispersment too, but I want advice from those who have used them or are going to use them
Thanks
Ryan24 is offline   Reply With Quote
Old 11-26-2002, 09:38 AM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
You want Euro beam.
I suggest you buy them from rallylights.com (Susquehana) as they do a good price for the kit.
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 11-26-2002, 11:19 AM   #3
STORER
Member#: 2253
2000 2.5 RS
Red
I agree with the Euro pattern. You might want to invest in Hella 2000's with normal driving pattern then replace your fog lights with Hella 500's. Adjust the 500's to light the side of the road so you can see signs, intersecting roads, etc. With this combo you have the best of both worlds, and you spend the same appro. amount of money.
Steve
STORER is offline   Reply With Quote
Old 11-26-2002, 11:58 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
definately Euro...
and definately buy from www.rallylights.com
if you want NO hassles...
cheers
Jamie
www.subiegalracing.com
visit the SubieGal Rally forums
Old 11-26-2002, 09:24 PM   #5
Ryan24
Member#: 451
2000 Impreza 2.5RS
I wouldn't buy them from anywhere else but from www.rallylight.com
I already have the driving Hella 500's(I used to have the fog's too but I decided to donate those to the BC wildlife ) but they are mounted on the light bar right now
The plan is to replace them with the 4000's and move the 500's down to where the stock fogs go with the Kartboy mount
Old 11-27-2002, 10:25 AM   #6
Corey
Member#: 618
2000 2.5 RS #89 STS
MODERacing / Bridgestone
I have the 4000's in the Euro pattern on my Blazer for late night excursions. They are wonderful. I can't believe that the pencil beam would shine any further, these things already shine as far as I need...
Corey #89 SM
Corey is offline   Reply With Quote
Old 11-27-2002, 05:24 PM   #7
Petrie
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
Euro is fine for what you describe. I originally had the pencils as well but they are just not worth it. The pencil beam is so compact it hardly ever points at what you are looking at.
Petrie is offline   Reply With Quote
Which tile pattern to use? RoadRashed Off-Topic 14 10-24-2008 02:59 PM
Which weight oil to use in this situation? armand1 Service & Maintenance 12 02-07-2002 02:16 PM
('93-'01) Which Transmission Fluid to use? 2yLiTe Impreza Forum 6 04-29-2001 12:04 AM
Which Brake Fluid to Use? silverSurfer Brakes, Steering & Suspension 21 02-03-2001 12:27 AM
