Old 11-26-2002, 01:59 AM   #1
gumby1976
Member#: 26248
2016 WRX
Lapis Blue
Default oxygen sensor
I got a short ram air intake that has a spot for the o2 sensor to go in but i have not located the sensor on my 02 2.5rs and have plugged up the openning.
If anyone knows where i can find it please let me know, my mpg is terrible and i don't want to risk harm to the engine.
thanks ahead of time
gumby1976 is offline   Reply With Quote
Old 11-26-2002, 11:02 AM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Gumby, I hope you're joking. O2 sensors go in the exhaust. What brand intake did you buy? The openings are for your breather lines and PCV, not your O2 sensor.
Old 11-26-2002, 12:34 PM   #3
gumby1976
Member#: 26248
2016 WRX
Lapis Blue
Default pcv???
it is an OBX intake that came without directions. A friend w/ a WRX told me the o2 sensor went into the opening with the rubber "gasket"??. when i took out the stock air box there was no sensor or anything electrical connected to it.
What is a PCV anyway, some kind of valve.
Old 11-26-2002, 12:37 PM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
The WRX has a Mass Air Flow sensor (MAF) that would go into the intake pipe, the 02 RS does not have a MAF sensor. Sounds like you may have gotten the wrong intake.
PCV=Positive Crankcase Ventilation valve
Old 11-26-2002, 01:33 PM   #5
windfactory
Member#: 16108
02GD Tuned EJ251 NA
Blue Ridge Pearl
Default here u go, just install it...
windfactory is offline   Reply With Quote
Front Oxygen sensor AKA air/fuel sensor swap out Peaty Tribeca Forum 0 02-20-2010 04:36 PM
2007 STi Rear Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 3 02-19-2009 11:49 AM
2007 STI Front Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 0 02-13-2009 02:16 PM
oxygen sensor vs air/fuel sensor paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-02-2008 01:09 PM
FS: Front oxygen sensor 04 WRX 02 sensor Chino Bling Engine/Power/Exhaust 4 11-20-2007 11:56 PM
