Old 11-26-2002, 03:54 PM   #1
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default RS-T's... Vacuum line configuration poll...
How do you have yours run?
Mine:
Brake booster (dedicated port, #4)
Boost Gauge (top of manifold with double T)
BOV (same T as above)
Wastegate (same T as above)
MAP sensor (#3 runner - IMO, bad)
FPR (#3 runner)
Also have to add cruise in the future.
I am looking at more places to add vacuum ports without massively drilling into the plenum. It's obvious to me at this point that pretty much everything needs to get constant pressure like in the manifold rather then the pulsed signals they get on the #3 runner. The only thing I have going for me is that I have a Haltech, so I don't need the stock MAP sensor.
Locations as I see for possible fabricating of ports :
Stock MAP sensor location (fab piece for it).
Removing fitting for PCV and put another between it and the manifold with extra locations.
Drill hole in top of manifold between MAP, coil, and IAC chamber (I have my IAT sensor here already)
Old 11-26-2002, 03:57 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
This is going to chance....
Brake booster on #4 dedicated (not messing with that one.)
#3 fpr
#3 BOV, MAP, Wastegate, Boost gauge.
Yah... It needs to change.
-B
Midwayman is offline   Reply With Quote
Old 11-26-2002, 04:01 PM   #3
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Let's see:
Brake Booster: stock
Top Manifold: MAP sensor TecII
Uppder Cyl3 Manifold: Boost Gauge, Fuel Pressure Regulator, bypass
Lower Cyl 3 Manifold: uhm..
Revision is offline   Reply With Quote
Old 11-26-2002, 04:15 PM   #4
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Brake booster, brake booster (where else would this go?)
Top manifold: fuel pressure regulator
Intake runner one: MAP sensor
Intake runner two: boost gauge, BOV
Never had a problem with anything, fuel pressure stays rock solid, BOV has always opened and shut when it should, boost gauge is responsive, and Link MAP signal seems responsive and steady.
wcbjr is offline   Reply With Quote
Old 11-26-2002, 04:20 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Both you guys forgot wastegate. Revision looks to have his on lower #3.
Old 11-26-2002, 04:34 PM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I've got a TiAL wastegate, I just leave the top nipple open. Am I not supposed to?
Old 11-26-2002, 04:44 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yes, the top one should be open, but the bottom one should be occupied by a line from the manifold or turbo outlet.
Old 11-26-2002, 04:48 PM   #8
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Ok, that's what I have. I chose the turbo outlet because the nipple is larger and I could use a bigger vacuum hose. I get absolutely no spiking.
Old 11-26-2002, 04:50 PM   #9
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Okay I need to go look at my nipples now.
Old 11-26-2002, 05:04 PM   #10
Delicious Tuning
Member#: 1990
The top nipple is for a dual port solenoid. So you have to hook it up slightly differently. But in the end will keep a more even and steady pressure on for the wastegate. Of course it all depends on the wastegate you are using, I have a crappy one so it really makes no difference. :P
Delicious Tuning is offline   Reply With Quote
Old 11-26-2002, 05:11 PM   #11
Revision
Member#: 242
MY05 PSM GGA !STOCK
My wastegate is off the turbo nipple.
Old 11-26-2002, 07:09 PM   #12
Aspen
Member#: 145
Banned to
Housework for Summer
All stock locations since I have the '93 Turbo Intake Manifold.
Aspen is offline   Reply With Quote
Old 11-26-2002, 07:15 PM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
man.. I have no idea. I think I am running most stuff off of the 2 rear vaccuum port on the passenger side of the manifold.
Eric
Eric SS is offline   Reply With Quote
Old 05-29-2009, 11:38 AM   #14
Skidd
Member#: 1853
GC6 Supercharged
STM
A bump from the dead.
Current Configuration:
Brake Booster - Stock
Aftermarket MAP - #3 (major pressure oscillation)
Boost Gauge - #3
Aftermarket FPR - Top
CBV - Top
I have my aftermarket MAP sensor plumbed into the #3 runner. I see an oscillation going from 2-8psi at WOT. It's causing my EManage to oscillate the fuel and ignition map to match. That's bad!
What I want to do is get one of those multiple-port vacuum fittings.. kinda like this one
But with 3-4 ports and a 1/8NPT end. I saw them at PepBoys for cheap.
Then, run my FPR, CBV, Gauge and External MAP all from the fitting installed at the top of the intake.
I can't see there being any problem with using one fitting with 3 lines from it. The lines will each be only about 6 inches long (except for the long plastic gauge hard-line).
Proposed Configuration #1:
CBV & FPR - #3
Boost Gauge & MAP - Top (with 2-way T)
Proposed Configuration #2:
Brake Bootser - Stock
CBV & FPR & Gauge & MAP - Top (with 4-way T)
Any reason why I should not do this? I always hear people say "Don't T the vac line for your FPR or your BOV", but I don't understand why? And, I've read posts waying "Always use a dedicated MAP line", but again, don't know if it's just a "good idea" or a "critical idea".
edit:
Or... perhaps just get/make one of these
http://www.maperformance.com/vibrant...ion-block.html
Skidd is offline   Reply With Quote
Old 05-29-2009, 11:56 AM   #15
Odyknuck
Member#: 192866
2006 Impreza
"T" ing into any device that uses a diapfram with another device will affect the signal the other device sees. "T" ing 2 diapfram devices together can cause osillation between the two devices. Note: Pieso electric type devices are less sensitive to osillation than a diapham due to less air volume being moved.
Odyknuck is offline   Reply With Quote
Old 05-29-2009, 11:59 AM   #16
Skidd
Member#: 1853
GC6 Supercharged
STM
^ Yeah... that's what I figured.
I'm looking into making/buying a vacuum distribution block/manifold now.
They should be a crap load better than multiple T fittings.
edit: Gotta love Google
http://www.harborfreight.com/cpi/cta...emnumber=96398
http://www.harborfreight.com/cpi/cta...emnumber=93979
http://www.northerntool.com/webapp/w...9566_200339566
Old 05-29-2009, 01:37 PM   #17
Odyknuck
Member#: 192866
2006 Impreza
Skidd, I have a nice Aluminum manifold that was on my VW motor before I switched it out to the Subie. I believe it has 5 1/8" NPT taps on the length and one on each end. If you interested in it give me a call.
Steve
216-695-0733
Old 05-29-2009, 01:48 PM   #18
Skidd
Member#: 1853
GC6 Supercharged
STM
^ Thanks for that offer Steve... but in re-thinking my layout, I'm going to go with
Cruize - #3
FPR & CBV - Top Port
Boost Gauge & MAP at PCV Port with some brass fittings - I've already deleted my PCV from the system anyway. It's a nice big 1/4NPT (I think).
I hope/expect that to fix the oscillation problem. If not, I just might hit you up for that manifold.
Old 05-29-2009, 02:10 PM   #19
Odyknuck
Member#: 192866
2006 Impreza
Cool, let me know if you need it. FYI as I recall the taps on the Intake manifold are metric however you can use SAE NPTs on them. You would be better off chasing them with a pipe tap however not nessasary.
Old 05-29-2009, 03:13 PM   #20
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
wow I've never seen this thread before.... Nice bump !
IllNastyImpreza is offline   Reply With Quote
Old 05-30-2009, 08:24 PM   #21
gumby647
Member#: 2532
2001 2.5RS-T
BRP
If you are seeing a 6 psi swing in manifold pressure something is wrong. There's no way you are seeing that difference just because you're sourcing one of the runners.
gumby647 is offline   Reply With Quote
Old 05-30-2009, 09:11 PM   #22
Skidd
Member#: 1853
GC6 Supercharged
STM
Well, I moved the source to the center port, and saw a 1psi swing. But, it was also Td off with 2 other devices (FPR & CBV). Now, I have my MAP by it's self. I just need to log it's values again. I expect to see little to no swing. Even the stock MAP sensor swings just a little.
Also, the 2-8 psi was the max oscillation. The average was more like 3-6. But, that's still a 3psi change, and resulted in a 3 deg difference in timing. Now, at least it's only a 1 deg affect, and hopefully less.
WTB: Restrictor pill for factory turbo vacuum lines & factory turbo vacuum lines roninsoldier83 Private 'Wanted' Classifieds 4 10-01-2007 09:14 PM
2002+ 2.5 RS location of vacuum lines? bahboy20 Normally Aspirated Powertrain 0 10-09-2004 04:03 PM
Does AZ have the largest ratio of RS-T's Eric SS South West Impreza Club Forum -- SWIC 4 10-05-2001 01:00 PM
I'm ready for those RS-T's Turbo4me South West Impreza Club Forum -- SWIC 7 07-20-2001 11:56 AM
Where can I find a small in-line air filter for vacuum line. Tim Prudence Normally Aspirated Powertrain 3 12-04-2000 03:38 PM
