Mid Atlantic Impreza Club
Old 11-27-2002, 01:47 PM   #1
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
Default Info on and where to buy new lugs??
I need to purchase some new(better) lugs, and I was wondering if anyone knew the specs on which ones to use on 17" rota subzeros and of course where to buy them.I currently have the stock lugs on there now..I've tried searching on tire rack, but for some reason I can't find them. Thanks
AustinSTi is offline   Reply With Quote
Old 11-27-2002, 03:06 PM   #2
Endlesshine
Member#: 19598
1998 Honda CR-V
Sold the LGT
Subaru fitting size is: 1.25x19mm
I just recently baught a set of SplineDrive nuts by McGard from www.cruisecontrolauto.com. Rob @ cruisecontrol will give you 10% off if you use WRX as your coupon code.
The SplineDrive nuts are neat in that the thread spins
inside the nut. The silver portion that fits against the wheel spins on it's own axis, that is, independently of the thread. That means that as soon as that portion of the nut touches and gets some pressure on the wheel it stops spinning. Then the thread just continues adding pressure on the wheels. No spinning ends mean no scratching the wheel surface at the contact point.
The kit comes with 16 nuts, 4 locks, a lock key and a lug tool. These are made for aftermarket tuner wheels, but I tried it on my stock wheels and it seems to fit fine. They have a cone-shaped tip.
Hope this helps. Good luck!
-Ron
Endlesshine is offline   Reply With Quote
Old 11-27-2002, 03:33 PM   #3
WRX11
Member#: 26638
Ron,
What did you end up buying in place of your missing nut?
WRX11 is online now   Reply With Quote
Old 11-27-2002, 06:01 PM   #4
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
I checked that site and the cheapest things they sold were $54. Maybe I'm missing something but isnt that a little expensive for 20 lugs?? I could really care a less if they are the locking type, or top of the line....i just need some long(er) lugs that I can actually take off without power tools....and 1.25 x 19mm is definitly the correct size??
Old 11-27-2002, 06:58 PM   #5
iceNine
Member#: 12170
2002 WRX Sedan
Platnum Silver Metallic
Check out www.subydude.com. He has some spline lugs in chrome finish. Don't know what make though.
Dale
iceNine is offline   Reply With Quote
Old 11-27-2002, 08:02 PM   #6
Endlesshine
Member#: 19598
1998 Honda CR-V
Sold the LGT
Austin, you said you were looking for newer (better) lugs, you didn't mention you had a budget I spent $92 on my lug set But it's a locking set so it's more expensive, plus they're a new line for McGard so it's like the cutting edge stuff or whatever.
Dale, I got black ones.
Good luck find lugs. I dunno who else sells what but you might want to try Advance. Just don't ask them any questions... they're heads are liable to blow up.
-Ron
Old 11-28-2002, 02:32 AM   #7
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
www.subydude.com does not work?? is there another site that works?
Old 11-28-2002, 09:24 AM   #8
iceNine
Member#: 12170
2002 WRX Sedan
That's odd. It works fine for me. Try www.subydude.com/parts/ for the link to the parts for sale page. The lugs are about 3/4 of the way down the page.
Dale
Old 11-28-2002, 12:36 PM   #9
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
its worked this morning for some reason
Where to buy tuner lug nuts locally? Donzo Tri-State Area Forum 15 01-10-2007 07:36 PM
where to buy STi lug nuts? DOHCammin Southern California Impreza Club Forum -- SCIC 9 07-07-2005 06:46 PM
Need new struts or used and where to buy? adam555 New England Impreza Club Forum -- NESIC 6 05-24-2004 08:13 AM
Anyone know where to buy rays lugs locally? FryRice Bay Area Impreza Club Forum -- BAIC 9 09-30-2003 06:24 PM
Suggestions on components and where to buy Overtime Car Audio, Video & Security 13 01-16-2001 10:54 PM
