Old 11-27-2002, 01:00 PM   #1
Equinox
Member#: 29623
Default Odd smell from under hood, steam.
I appear to have a strange, dirty water/burning rubber smell coming from the general vicinity of my turbo. There is no performance decrease, and no fluid level change.
Im frankly afraid to drive my car, any help is appreciated.
Mods are: Injen CAI, TXS Turbo back, freedom design strut tower brace, TXS BOV, TXS dual stage boost controller.
Equinox is offline   Reply With Quote
Old 11-27-2002, 01:29 PM   #2
DammitBevis
Member#: 3569
2006 STi
AW
Sounds like a coolant leak. An oil leak will usually drip since the oil doesn't evaporate. They can be irritating to track down. Look for a white residue left behind by evaporating coolant, or puffs of steam while the cooling system is fully heated up. When it's hot squeeze the radiator hose to make sure the system is under pressure (be careful). First place I'd check is under the turbo heat shield.
DammitBevis is offline   Reply With Quote
Old 11-27-2002, 02:05 PM   #3
I drive a WRX wagon
Member#: 9219
02 IS300 5sp
yep, i had the same problem and took my car to the dealer. The dealer said that it was a loose fitting coolant hose that was leaking on to the turbo. They fixed it under warranty
I drive a WRX wagon is offline   Reply With Quote
Old 11-28-2002, 12:33 AM   #4
KKL
Member#: 10220
2010 STI
World Rally Blue Pearl
Odd, I had the exact same problem a few months after I got my car, also a wagon. I kept seeing these little wisps of steam coming from the hood scoop and couldn't figure out what it was at first.
KKL is offline   Reply With Quote
Old 11-28-2002, 12:20 PM   #5
savka
Member#: 12737
MY02 wagon 325/300
MBP
me too!!
any danger in ignoring the occasional white wisp of smoke?
savka is offline   Reply With Quote
Old 11-28-2002, 12:25 PM   #6
aphex twin
Member#: 10426
Midnight Pearl Black
damn! i posted about this not too long ago. i was having the same problem. it wasnt a regular occurance so i couldnt figure it out. coolant makes sense. does it happen sporadically for you guys too?
aphex twin is offline   Reply With Quote
Old 11-28-2002, 06:14 PM   #7
KKL
Member#: 10220
2010 STI
In my case, it started out as very small puffs of white smoke that I would catch out of the corner of my eye. I thought I was seing things for a while. It eventually got a little worse, enough that I could tell for sure that it was steam coming out of the hood scoop. By that time, I could smell the burning anti-freeze, not a nice smell. The dealer found the cause was a loose hose clamp underneath the turbo causing coolant to spray onto the turbo itself. They replace the clamp under warranty and it hasn't done it again in over a year.
Old 11-28-2002, 07:49 PM   #8
Equinox
Member#: 29623
Aphex, on mine it has been sporadic, occasionally, it wont happen for long periods of time, and then it will just REEK in my car.
Help: Gas smell from under hood. ChrisF Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 103 05-06-2010 02:04 AM
gas smell from under hood! tcooper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 12-05-2009 09:43 PM
Steam from under hood Thtwudbeme Outback Forum 0 12-14-2003 11:21 PM
Steam from under hood, and excess coolant consumption ErikAnderson Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-15-2003 11:36 AM
Showoff Q: Mist/Steam from under hood when revving? Brian Broz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-25-2003 06:43 PM
