Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Vancouver Impreza Club
Old 11-27-2002, 04:31 PM   #1
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
Default Clutch shudder on 2002 TS
Hey boys and girls!
Quick question for you: I did a search on this forum for this, but could not really find any specific info.
My newly bought 2002 Impreza TS is approaching 12000 kms. The car has been showing the signs of the famous "morning clutch shudder". In fact, the problem is getting worse and worse every day.
(I used to live in Montreal, and know quite a few people for the Montreal Subaru Club, so I have heard that this quite a common problem with the clutch -- I bought the car here, however)
I have an appointment at Docksteader service next week, and I am wondering if anybody was able to get the clutch changed/repaired under warranty? If so, which dealer did you go to? I'd like to have as many arguments as I can about that problem...
Thank you. And I apologize if this has been discussed in here before. I did use the search function..
Okeo is offline   Reply With Quote
Old 11-27-2002, 05:13 PM   #2
Benjamin Tang
Member#: 4496
2009 Forester
red
i had my clutch replaced. they did the flywheel too. it was written up as defective/warranty replacement. but when that happened it never went away, warm or cold.... it was really brutal to drive
with the new stuff i still get some minor chatter on cold mornings. but when things warm up it goes away.
Benjamin Tang is offline   Reply With Quote
Old 11-27-2002, 05:48 PM   #3
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
Yup, same here, it eventually goes away too. But you have to ride the clutch MUCH more than usual for it to disappear.
If you don't, the whole car shakes, that *can't* be good for the transmission. And it went from being just on cold morning, to being all mornings, to happening after the car has been parked for 3-4 hours.
As I said, it *does* go away eventually, but it definitely is not how the clutch should work on a new car...
Thank you for your reply.
Old 11-27-2002, 06:42 PM   #4
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
I've had morning clutch shudder pretty much since my car was new (now over 18,000km and still going strong ). The options are to do an agressive clutch slipping launch or ignore it until it warms up. Let us know what Docksteader says/does about it.
AllWheelDrift is offline   Reply With Quote
Old 11-27-2002, 09:11 PM   #5
jengyigin
Member#: 8209
2002 impreza 2.5 RS
blue ridge pearl
Yup, just like Okeo said, my clutch shudder started to go away after a while. I also brought my car into Specialty to get the clutch shudder looked at, and they just said my clutch is ok - no need to replace or repair.
jengyigin is offline   Reply With Quote
Old 11-27-2002, 11:01 PM   #6
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
So is it still doing it in the morning or not?
Old 11-28-2002, 01:32 AM   #7
Reset
Member#: 11118
2002 2.5 TS
Aspen white
I don't have clutch problem...wait... I don't even have clutch
get to love the auto
Reset is offline   Reply With Quote
Old 11-28-2002, 04:22 PM   #8
Wrx31
Member#: 994
'99 Impreza RS/RBP
'88 RX-7 (resting)
I was told by a dealer that a clutch is a wear and tear item, and therefore would not be possible to have it replaced under warranty.
Wrx31 is offline   Reply With Quote
Old 11-28-2002, 05:34 PM   #9
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
All this time I thought it had to do with the pressure plate..
Mirage is offline   Reply With Quote
Old 11-28-2002, 10:54 PM   #10
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
Well, from the people I know that had it changed under warranty for the problem I am describing, they actually do three things:
  • Change the clutch disc
  • Change the pressure plate
  • Re-surface the flywheel
So maybe you're not totally wrong.
Old 11-29-2002, 01:18 AM   #11
Parousia
Member#: 24252
05 Legacy GT LTD
Satin White Pearl Wagon
I dont have much chatter, but I am having problems getting mine into 1st gear, and reverse.
When I try to get it into reverse it even grinds sometimes with the clutch fully depressed, and it even ginded when I was shifting into 4th today?
Have you experienced this problem?
Parousia
Parousia is offline   Reply With Quote
Old 11-29-2002, 01:20 PM   #12
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
Well, yes, sometimes the first and the reverse gear are hard to engage.. For the first, it won't let me engage it until my speed drops below approx. 25 km/h. As for the reverse, I never force things, so I sometimes go back to 5th, and then the reverse gear will engage better.
But I have never experienced grinding with the clutch pedal fully depressed, like you mentioned. That sounds a little weird.
Old 11-29-2002, 01:58 PM   #13
jengyigin
Member#: 8209
2002 impreza 2.5 RS
blue ridge pearl
since reverse has no synchros, you have to come to almost a complete stop before you pop it into reverse. otherwise, you will hear and feel a grinding noise regardless of how far down you're stepping on the clutch. My clutch still shudders once in a while, but not as often as before.
Old 11-29-2002, 09:25 PM   #14
-S-
Member#: 6979
Reverse is just a PITA to get into the first thing in the morning, despite double clutching and what not
As for the clutch chatter, Steve at Specialty said "Huh? I've never heard of that" even though I know Penphoe, Ken and other people have mentioned it before. Go figure.
-S- is offline   Reply With Quote
Old 11-29-2002, 09:47 PM   #15
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
Hmm... Well, I am just afraid I will be given the same kind of treatment next week when I go for my scheduled service...
Even though it's a common problem, and one that Subaru Canada has actually worked on. We'll see, keeping my fingers crossed.
Old 12-06-2002, 05:11 PM   #16
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
Exclamation
BUMP.
Wanted to let you know guys how things worked out... maybe this could help some of you.
Well, I had my maintenance service yesterday at Docksteader's. I left the car last night so they could try the clutch in the morning.
Called me back this morning saying that they had experienced the shudder, and that they would change the clutch assembly under warranty.
Right now, they have contacted Subaru Canada, and I am on a list to get the new clutch assembly. Don't know how long it will take, however.
I'll let you know how things go on that front.
Old 12-06-2002, 07:01 PM   #17
Koyo
Member#: 19332
Of course the clutch is a wear and tear item. Every time you depress the clutch, it bite into the spinning flywheel. These people have it under warrenty because it's a premature failure or defective workmanship. I read at the noob form that SOA is aware of the problem but since it's not a dangerous problem, there won't be a recall.
Koyo is offline   Reply With Quote
Old 12-07-2002, 07:31 PM   #18
Benjamin Tang
Member#: 4496
2009 Forester
red
i heard something similar as well. a recall is issued only when there is a safety hazard concern, such as seat heaters catching fire (audi?) or your power steering pump fails (GM minivans)... unforuntately a shuddering clutch is not considered to be a hazard... athough the headache it created for me rattling my noggin and loose change all over the place says otherwise
Old 12-07-2002, 09:00 PM   #19
Koyo
Member#: 19332
Damn...remind me not to fart while I'm sitting in an Audi. You should read the new investagation US feds are doing. One GM engine back fires, cracking the intake manifold and causing fuel leak. I'm surprise Toyota, Honda, and Nissan are all being investagated too.
Progresively worsening clutch shudder on 2005 Saabar. New Clutch Carlito2002WGN Transmission (AT/MT) & Driveline 2 07-12-2007 12:44 PM
Clutch Shudder on aftermarket clutch/flywheel. firedog25 Transmission (AT/MT) & Driveline 9 02-07-2005 02:09 AM
my 4eat feels like clutch shudder on a 5mt? WRXout Transmission (AT/MT) & Driveline 2 08-03-2004 12:56 PM
clutch shudder on '02 WRX john wilfley Rocky Mountains Impreza Club Forum -- RMIC 35 07-02-2003 02:51 PM
Clutch shudder on Clutchmasters I n555wrc Transmission (AT/MT) & Driveline 3 02-17-2002 03:53 AM
