Old 11-27-2002, 06:15 PM   #1
mikaust
Member#: 7468
2008 Outback Limited
Default Utec knock
How do you know if the knock correction is set? . Mine is set on disable. Thanks Michael
mikaust is offline   Reply With Quote
Old 11-27-2002, 07:25 PM   #2
mikaust
Member#: 7468
Phil walked me through it. This Utec is sweet!!!! Thanks Michael
Old 12-01-2002, 02:52 AM   #3
air_scooby
Member#: 24243
2002 wrx sportwagon
Default share the news
hi. let us know the results of Phil's conversation with you, how do you fix the knock issues?
air_scooby is offline   Reply With Quote
Old 12-01-2002, 07:53 PM   #4
mikaust
Member#: 7468
If you are looking at the utec dashboard screen and the car is not started it will show the knock correction disabled. Once the car is started the disable code is gone and the level of knock detection will appear. You can then go to the parameter section and check the level of knock correction at different rpm's. The settings are preset to high knock detection levels (very sensitive), if you want to change the level of knock correction be advised this could and would be a problem if detenation were to happen and the proper timing cycles were not in place.
Mysterious 2004 UTEC knock FIXED! GMTarkin Engine Management & Tuning 4 08-20-2003 01:29 AM
04 UTEC Knocking! GMTarkin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-03-2003 02:22 AM
04 Utec knocking!! GMTarkin Engine Management & Tuning 7 08-02-2003 04:16 PM
UTEC Knock Sensitivity Settings AaronC Engine Management & Tuning 1 06-24-2003 05:00 PM
UTEC knock correction Big Turkey Engine Management & Tuning 30 05-15-2003 08:29 AM
