Old 11-28-2002, 01:57 AM   #1
zaidallas
Member#: 4106
Default What size bung is needed for factory EGT probe ?
I got an uppipe with no egt bung and need to add one to fit the wrx factory probe ( I don't have a probe to look at). Anyone done this ?
zaidoun
zaidallas is offline   Reply With Quote
Old 11-28-2002, 01:26 PM   #2
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Not the reply you're looking for... but I wouldn't do this.
The stock EGT sensor fails in under 1000 miles after switching to an up-pipe.
Mine failed 3 hours from home. The car went into "limp nowhere mode". She'd start and idle, but would die when given any throttle. Turned out the EGT sensor had fried and the CPU thought the engine was on fire! I had her towed to a shop and drove home in my girlfriend's car (we were at a track day).
Disconnecting the EGT sensor from the wiring harness was a temp fix. If I'd only known!
Later, I had to find a bolt that fit the EGT bung in my up-pipe, grind it down to the right length, and plug the hole. Then I used the resister mod to keep the ECU happy with EGTs.
So I wouldn't waste time & money on a mod that won't help you and will likely fail. The stock EGT sensor is there to protect the up-pipe cat. And since you don't have one...
Russ
rlavalle is offline   Reply With Quote
Old 11-28-2002, 01:30 PM   #3
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Exactly what he said! Mine came with a bolt to plug the EGT bung. Go to Radio Shack, get a 2.2K ohm resistor, spade connectors and some electrical tape and insert that into the connector. Remove your EGT probe and install it on the shelf \
No CEL for me (well except for that rear O2 and the Fuel Cap one)
-Tom
trhoppe is offline   Reply With Quote
Old 11-28-2002, 01:38 PM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
I've been running with my stock EGT sensor in my Vishnu uppipe for over 7000 miles and never had a problem so I don't think it happens to everyone. It's up to you. . although I would agree that it's probably a lot easier to do the resistor mod than it would be to drill and weld a bung on your brand new uppipe.
Calvin
cnk is offline   Reply With Quote
Old 11-28-2002, 01:39 PM   #5
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Tom, I sent you a PM.
Russ
What size turbo is needed to hold ~22 psi up to 6k rpm's on a 2.5L? sburck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 51 03-19-2009 03:02 AM
any1 know what fabrication work is needed for older exuast to fit 2.5i? subiesurfer Normally Aspirated Powertrain 3 03-06-2008 09:47 AM
Looking for a EGT probe bung. fragment Canada Region Forum 5 02-23-2005 11:34 AM
Is 1/8NPT the right tap size for Defi EGT probe? ssitu Electrical & Lighting 5 07-10-2004 03:20 PM
What size tapping device is need for Autometer EGT probe? sdseagles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-13-2002 12:40 AM
