Old 11-28-2002, 07:46 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Changing the Spark Timing
my timing is too advanced, im getting a backfire thru my intake valves. so how do i set it back a few degrees? thanks ahead of time!
Brent
scoobyimprza is offline   Reply With Quote
Old 11-29-2002, 07:38 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
Brent- it's detonation, not backfire, i had some.. and look where my motor is now.. Your timing is off, you need to pull the timing belt and put a new one on. check your plugs and coil pack.
rhdude is offline   Reply With Quote
Is changing the spark plugs multiple times necessary after a new build? blowbyu24 Built Motor Discussion 5 03-28-2007 05:19 PM
Should I Change the Spark Plugs? 2002 with only 30k miles bjy20716 Newbies & FAQs 1 07-13-2006 02:49 PM
I can't even change the SPARK PLUGS myself!!! Sporqster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-28-2005 09:55 AM
Is it necessary to reflash the ECU if I change the spark plugs? skyline31 Service & Maintenance 11 04-28-2005 05:30 PM
Changing the Spark plugs NDzToYCaR Bay Area Impreza Club Forum -- BAIC 8 04-24-2004 06:20 AM
