Old 11-29-2002, 10:06 PM   #1
Rovah
Member#: 1375
2003 WRX Rally Car
Default TPS wiring help needed ASAP! :-)
Guys,
Trying to finish the wiring of the '99 ECU into the 1.8L car. Turns out our TPS has four wires instead of the three shown on all the diagrams we can find online and in print.
Can anyone help us out? We really need to know what each pin does. The engine is supposed to be from a '99 RS, but now, we're not so sure.
This is the last thing we need to wire before we try and start the car(except maybe a fire extinguisher).
Cheers! John
Rovah is offline   Reply With Quote
Old 11-30-2002, 03:19 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
John, I just checked my 2000, and the TPS has three wires- the 2000 manuals concur as well . I can check the 99 manuals when I get to Exeter on Monday if you like.
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.deniedmywarranty.org
Old 11-30-2002, 10:25 AM   #3
Rovah
Member#: 1375
2003 WRX Rally Car
Brian,
That would be helpful, although Wayne called me last night(thanks Wayne!) and told me that the fourth wire is probably a sheild ground and we just need to use a multimeter to figure out which wire is which.
If you can get us additional info, that would be great. The engine came from Canada, and was supposedly from a '99 2.5RS. The only four wire TPS I can find is from a turbo engine, and that diagram doesn't help us at all.
Wayne didn't tell me why he thought we had a four wire though....hmmm...
Cheers! John
Old 11-30-2002, 11:37 AM   #4
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
The fourth wire might be an idle switch, that tells the ECU when you are at fully closed throttle... it's a Japanese thing, a lot of older Japanese cars had it, and some still do.
yamarocket630 is offline   Reply With Quote
Old 11-30-2002, 12:26 PM   #5
Rovah
Member#: 1375
2003 WRX Rally Car
Strange thing is, NO '96-02 wiring diagrams show a four wire TPS on NA 2.5 engine. This is definitely a late model 2.5 RS engine.
Guess we have a strange aberration here...
Cheers! John
Old 11-30-2002, 03:04 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Legacy777 is offline   Reply With Quote
TPS, bpv, 02sensors need asap Richbmxer87 Private 'Wanted' Classifieds 5 10-27-2009 10:55 PM
need ASAP : 05-06 WRX/STicenter trims... STi-JDM Private 'Wanted' Classifieds 22 07-05-2006 11:02 PM
NEED ASAP!: 04/05 STI Fuel Pump Control Unit aka Fuel Pump Controller. dan2304k Private 'Wanted' Classifieds 0 05-25-2006 08:25 PM
TPS wiring help needed ASAP! :-) Rovah New England Impreza Club Forum -- NESIC 3 11-30-2002 11:27 AM
Springs...help needed asap legacyej22 Legacy Forum 5 09-04-2002 08:39 PM
