Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-01-2002, 02:11 PM   #1
Tirewarmer
Member#: 19667
2013 BRZ
1996 Mazda Meotter
Default STX guys - Go ahead and order your 245's
http://www.scca.org/news/fastrack/03-01.pdf
The SEB has made the recommendation to the BOD that the rule be changed to 245 for STX. I think its safe to buy tires now Mr. Hoppe and KC.
Joe
Tirewarmer is offline   Reply With Quote
Old 12-01-2002, 04:04 PM   #2
KC
Member#: 442
13 Crosstrek XV
00 S2000
Beefy!!!
KC is offline   Reply With Quote
Old 12-01-2002, 04:56 PM   #3
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
bye bye ITR
ellisnc is offline   Reply With Quote
Old 12-01-2002, 05:29 PM   #4
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Maybe I should go into the "rolling fenders" business.
Should be interesting to see these rims+tire combos on some Subarus.
I'll stick with my 205/55R16 Azenis and use the smaller size as another excuse I can't win.
Paul G.
paultg is offline   Reply With Quote
Old 12-01-2002, 06:28 PM   #5
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
245/40/17 KDs for front
225/45/17 KDs for rear
-Tom
trhoppe is offline   Reply With Quote
Old 12-01-2002, 07:37 PM   #6
zoomfactor
Member#: 30440
03 WRX
WR Blue
What about some 11 pound 15x8 rims?
zoomfactor is offline   Reply With Quote
Old 12-02-2002, 09:02 AM   #7
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
-Tom
Glad to see they're nice and cheap! 245/40-17 Hoosiers are cheaper!
I think I'll either stick with the 225 Azenis or get some 245/40 Ecsta MX's for now and wait until June/July to see if I'm going to Nationals.
Orion is offline   Reply With Quote
Old 12-02-2002, 09:08 AM   #8
KC
Member#: 442
13 Crosstrek XV
00 S2000
Find a 245 tire in a 15". Closest I could find is a 245/50-15 Dunlop SP8000. A couple years ago, this was a good tire. But now, it's been passed.
The widest 15" performance tire I could find is a 225.
--kC
Old 12-02-2002, 09:41 AM   #9
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Yup, same thing with 16" wheels. SO3s come in a 235, but they are not going to be a competitive tire.
We will pretty much have to go to 17" wheels to get 245s that will win.
Im still having some issues with the rear tires though. I wonder if the 245/40/17 has any chance in HELL of fitting in the rear of the car. I know the 225/45/17 should fit no problem, but Im a little weary of running the car staggered and worried about the center diff a little. I know of a few people that have stuffed 245/45/17 Kumhos under the car but no one with a 245/40/17.
Anyone here have 225/45/17s with ROTAs that could see how much room there is between the strut and the fender???
-Tom
Old 12-02-2002, 11:41 AM   #10
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
Tom,
Michilin pilot sport come in a 235. Aren't they Porche OEM? A 245/40/17 should fit the rear (sedan) depending on the strut used
ChrisW is offline   Reply With Quote
Old 12-02-2002, 11:51 AM   #11
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
As I was saying "competitive" tire that means Azenis and KD
Im using tein coilovers. Car is lowered a bit. Im thinking about just order two tires now. Try them on the rear first. If they don't rub too badly then order two more.
-Tom
Old 12-02-2002, 02:19 PM   #12
dachoe
Member#: 16469
[hijack] who's STX #5?? Orion or trhoppe? both of you have #5 STX in your profile thingy... [/hijack]
damn those tires are expensive i'll stick with RE92's for now.
dachoe is offline   Reply With Quote
Old 12-02-2002, 02:26 PM   #13
zoomfactor
Member#: 30440
03 WRX
WR Blue
Tom,
Please post your "rub test"!
I'm considering the Volk CE-28N's in 17x8 with kd's. I just need to sort out the coil-over situation.
Regards,
jd
Old 12-02-2002, 02:28 PM   #14
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
My car rotates at will. Its all in the suspension setup.
muahahahahahahaha mayyyybe
Oh, and Im STX #5, Orion just wants to be
-Tom
Old 12-02-2002, 02:28 PM   #15
zoomfactor
Member#: 30440
03 WRX
WR Blue
Just a thought...
Since so many people have posted about how the car doesn't want to rotate, will the fatter 245 rubber call for more dramatic suspension geometry - toe out?
Now we're into the voodoo
Old 12-02-2002, 02:40 PM   #16
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
-Tom
Whatever, just check the 2002 STX Nationals entry list pal....
You snooze, you looze....
OK, so 245 tires are allowed, what wheels are we gonna be putting these bad boys on??? I don't think my 17x7.5's are the optimal rim for a 245/40-17. Heck a 235/40-17 would be a bit much!
Old 12-02-2002, 03:24 PM   #17
KC
Member#: 442
13 Crosstrek XV
00 S2000
Ok, now we're talking rolling diameter. The 245/40-17 tire has almost the same rolling diameter as a 225/45-17 or a 205/55-16, which will keep the speedo errors low. (The 245/40 is .6mph slower at 60mph... when the speedo reads 60, you're really going 59.4... the 245/45 with the speado reading 60, you're really going 61.7)
A 245/45-17 will have a higher rolling diameter than a stock rolling diameter... which means it's a taller tire than the rest. For sake of auto-x, it may not be the tire size to have, and in our cases, shouln't be thought about. Only the 245/40-17 is the tire. You *don't* want taller gearing at an auto-x.
Most 245/40's are recommended to be mounted on an 8" rim minimum. (Tire rack lists these under the tire specs)
--kC
(And #5 at National events comes down to who sends in their payments/registration to national HQ 1st. )
Old 12-02-2002, 04:43 PM   #18
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
--kC
Correct, but what 17x8's are readily available and in what offset? 17x7.5 w/ 48 offset is the most commonly found wheel, but I've seen very few 17x8's.
Orion
#5 STX - mine's sent for the 2003 season already.
Old 12-02-2002, 04:50 PM   #19
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Orion is a bastard.......
I will be stuffing my 245/40/17s on 17x7.5" Rota Attacks with a 48mm offset.
-Tom
Old 12-02-2002, 05:11 PM   #20
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
-Tom
how about i'll run #5 and you can run #105 or vice versa?
that's what I was gonna do with the 245/40 MX's since buying a house makes another set of wheels impossible right now.
too bad Falken won't be introducing new Azenis sizes. i'll be calling them soon since they sponsor my team. maybe we can put a little pressure on them.
Old 12-02-2002, 05:17 PM   #21
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
I believe Volk makes the TE-37 in 5x100 17x8 ET 45 (also 42 iirc), which IMO should be the ideal wheel for fitting 245s. Plus a baseball bat of course
I cant afford a set of $2k wheels but for those of you who can pay to play, go for it!
elgorey is offline   Reply With Quote
Old 12-02-2002, 05:21 PM   #22
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
100 + number is reserved for codrivers. Im just kidding on the whole #5 thing, I will take anything that has a 5 in it. 5,15,25,55 whatever is free
For me, the price of the KDs makes it impossible for me to buy wheels as well, so I have to stick with the Rotas.
Check out http://www.robsaudiworld.com/fender.htm
for fender rolling. He rents a fender rolling machine. $50 plus shipping both ways. It ends up costing about $75, but I would rather do that then try it with a baseball bat. This way seems much safer and better for me. Im on the list and will have this sucker in raleigh around the end of december
-Tom
Old 12-02-2002, 05:49 PM   #23
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
exactly my point!
-Tom
lemme know how the roller works out. i'll be running my 225/45 Azenis until they're dead so i've got plenty of time to watch your progress/mistakes!
Old 12-02-2002, 06:04 PM   #24
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
exactly my point!
aaaahhhhhh...... :slaps forehead:
Like I will actually tell people that I make mistakes, all you will see is the progress!!!!!
Example: "I got 245s to work just fine" instead of "after trying 3 different wheels, 3 different tire rollers, blistering my fenders, then repainting, I finally got the damn pos 245s to barely fit"
-Tom
Old 12-02-2002, 06:18 PM   #25
ChrisDP
Member#: 5879
'02 STX WRX
STS Civic, ITA Integra
Tom, after seeing the car we saw and said "ruhroh, rowd ee doo dat?!" with the 245 Kumhos on the car... I'm thinkin a street tire should be narrower section width than a race tire, and those 245/40s will be a slightly shorter tire too, giving you a little extra fender height to play with. I don't see why a 245/40 with rounded shoulders would be more difficult to squish in than a 245/45 with square shoulders.
ChrisDP is offline   Reply With Quote
I am going to go ahead and leave this righ here HighWayDrifter Off-Topic 21 04-15-2009 08:11 PM
I'm going to go ahead and call it.... Grap Off-Topic 20 02-21-2006 06:12 PM
Well, I went ahead and ordered borla headers and exhaust pillaka Normally Aspirated Powertrain 15 07-04-2002 02:22 PM
Should I go ahead and yank it or wait? wrxman555 Normally Aspirated with bolt-on Forced Induction Powertrain 9 07-30-2001 07:18 PM
