Old 12-01-2002, 04:56 PM   #1
Martin
Member#: 11054
2000 2.5RS
Default are heads from 99rs the same as 2000rs?
i need some help there
Martin is offline   Reply With Quote
Old 12-01-2002, 05:02 PM   #2
PsychO
Member#: 5947
MY02 Impreza STi V7
Can we simply take the heads of a 2000RS.......and bolt-in on a 99RS block?
And if YES, I know that there's a procedure to screwback the heads......does someone know what it is exactly?
PsychO is offline   Reply With Quote
Old 12-01-2002, 05:36 PM   #3
rhdude
Member#: 6637
2009 Acura MDX Sport
the MY99-01 all shared the exact same motor(other than manifold). You guys are lucky, no need to remove the cams like us DOHC people
as for bolt pattern and torque, I'll have to go look it up...
~Brian
rhdude is offline   Reply With Quote
Old 12-01-2002, 05:56 PM   #4
rhdude
Member#: 6637
ok.... here we go...
___________________________________
(10) (6) (2) (3) (7)
(9) (5) (1) (4) (8)
<---front of motor
thats the sequence for tightening, sorry I could'nt find torque specs, but they are not too tight, remember, they go into aluminum... My felt around 30lbs of torque? maybe a little more...
Old 12-06-2002, 04:57 PM   #5
PsychO
Member#: 5947
MY02 Impreza STi V7
COOL
Thanks a lot fellas. I never expected you guys to answer so quickly and so precicely.
Thanks again
Old 12-06-2002, 08:13 PM   #6
rhdude
Member#: 6637
no problem, and one more thing to note, Always use new headgaskets when putting heads on, never re-use your old ones.. and make sure the seal on the valve covers is not torn in any place.
Old 12-06-2002, 08:14 PM   #7
Jademonkey
Member#: 9213
2000 RS
Red
If you do a search under my name for the service & maint forum, I think you'll find it. That or this one.
Jademonkey is offline   Reply With Quote
Old 12-10-2002, 06:05 PM   #8
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Straight from the manual...
(bolt pattern)
(c) (a) (f)
(e) (b) (d)
1. apply a coat of engine oil to washers and bolt threads.
2. tighten all bolts to 22 ft-lb in alphabetical order. then tighten to 51 ft-lb in alphabetical order.
3.back off all bolts by 180 degrees; then again by 180 degrees
4. tighten bolts (a) and (b) to 25 ft-lb
5. tighten bolts (c) (d) (e) (f) to 11 ft-lb
6. tighten all bolts by 80 to 90 degrees in alphabetical order
7. further tighten all bolts by 80 to 90 degrees in alphabetical order.
CAUTION: do not exceed 180 degrees in last two steps.
Chuck is offline   Reply With Quote
Old 12-10-2002, 08:26 PM   #9
rhdude
Member#: 6637
Chuck, thats for a MY98. '99+ has 10bolts.
Old 12-10-2002, 10:53 PM   #10
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Are you talking about the head bolts or the bolts that holdt he cam plate on? I'm looking at the 2001 engine manual right now and I looked at the 2001 SOHC engine that's sitting on the stand in my garage. There are 6 head bolts, but there are 10 bolts that hold the cam plate on.
Are 2004 sti gauges the same as the 2005? bouse1 Interior & Exterior Modification 0 04-07-2010 12:05 PM
Are '02 WRX fans the same as '04 TS Fans?! Peter.Lombardi Subaru Conversions 0 05-11-2004 01:27 PM
Are 02/03 Tailights the same as 04? 2RS's4US Interior & Exterior Modification 7 02-20-2004 05:55 PM
are 03 WRX Transmissons the same as 04 wrx transmissions? M3toWRXin3seconds Transmission (AT/MT) & Driveline 1 01-28-2003 05:58 PM
Are 98 OBS headlamps the same as 98 Impreza RS Lamps? Rallyspec North West Impreza Club Forum -- NWIC 2 05-07-2002 03:03 PM
