Old 12-01-2002, 09:24 PM   #1
DOROPPU3127
Member#: 26150
03 IMPREZA WRX
RALLY BLUE
Default Please Help......The car sometimes stalls when I shift to neutral on the road
I have a 2003 wrx with Blitz intercooler and air intake installed, but there is a problem after I stalled these, the car sometimes stalls when I shift the gear to neutral while I drive on the road ( rpm drops to zero and the engine stops)...... so is there any one who knows what the problem is and how to fix it.....Thanks for your help
Doroppu3127
DOROPPU3127 is offline   Reply With Quote
Old 12-01-2002, 09:33 PM   #2
SubEd
Member#: 717
Can you explain, without cursing, what **** means?
SubEd is offline   Reply With Quote
Old 12-01-2002, 09:47 PM   #3
DOROPPU3127
Member#: 26150
03 IMPREZA WRX
RALLY BLUE
Sorry i didn't mean to write that.. what i meant was *SHIFT*.
THX
Old 12-01-2002, 10:05 PM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
Just a guess, but maybe with the increased air space due to the FMIC, there may not be enough pressure to get air into the engine when you shift into neutral causing the engine to stall.
Calvin
cnk is offline   Reply With Quote
Old 12-01-2002, 10:44 PM   #5
DOROPPU3127
Member#: 26150
03 IMPREZA WRX
RALLY BLUE
Thanks Calvin,
so what should I do to increase the air pressure?
Old 12-02-2002, 12:36 AM   #6
cnk
Member#: 10757
Like I said before. . I'm no expert and I'm just guessing. You may have better luck posting this in the FFI forum. If I had to guess, it may be that the stock turbo is not providing enough air to the longer intercooler piping. Most people that upgrade to a FMIC also upgrade their turbo's. If you stick with the factory turbo, you're actually better off with the TMIC. Not sure if other's have upgraded to a FMIC with the stock turbo though.
Best bet is to post in the FFI forum. Good luck.
Calvin
Old 12-02-2002, 08:40 AM   #7
Austin
Member#: 7089
2016 STi
The motor creates a vacuum in the intake manifold, which sucks air in anytime you're not on boost. That's how normally aspirated cars are able to run without a turbo.
You have a vacuum (air) leak between the MAF sensor and the throttle body. Tighten up all your piping connections.
Austin is offline   Reply With Quote
Old 12-02-2002, 11:22 AM   #8
DOROPPU3127
Member#: 26150
03 IMPREZA WRX
RALLY BLUE
Thanks Austin..I will check all pipes today.
OT Help my friend win contest! Just need you to click on the link! Chewyguru Off-Topic 25 12-18-2008 10:42 PM
Going to the dealer today. Should I switch back to stock on the ECU? EsTeaEye Newbies & FAQs 10 01-10-2008 04:57 AM
Why does my clutch release when I start to push on the peddle? Brooke Transmission (AT/MT) & Driveline 5 11-03-2005 09:42 PM
Please Help......The car sometimes stalls when I shift to neutral on the road DOROPPU3127 Normally Aspirated Powertrain 4 12-02-2002 11:41 AM
Please Help......The car sometimes stalls when I shift to neutral on the road DOROPPU3127 Engine Management & Tuning 4 12-02-2002 11:18 AM
