Old 12-01-2002, 10:08 PM   #1
Teamugi
Member#: 7771
Default Oil temp sensor
I don't know if this is the right forum. Sorry, if it is not. But I was able to get a used factory oil temperature gauge, but not the oil temp sensor. Does anyone know if I can just get an oil temp sensor from Autozone/Napa or should I just order the part from Subaru? This is for a 2001 RS. Thanks for any info.
Teamugi is offline   Reply With Quote
Old 12-01-2002, 10:15 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Parts store won't have what you need.
The sensor is integrated into the oil drain plug, when you install the gauge the original drain plug is replaced with the new plug/sensor unit. Your best bet would be the dealer, assuming the sensor is available as a separate part.
There are sensors available for other aftermarket gauges but these may not be compatible with the factory temp gauge and the resulting readings could be inaccurate.
Old 12-01-2002, 10:49 PM   #3
Teamugi
Member#: 7771
Thanks mulder.
THat is what I thought. Man, this car is getting expensive.
Oh well, no GF so money has to go somewhere
Old 12-01-2002, 10:58 PM   #4
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
http://www.subaruparts.com/ is pretty reasonable from what I have read but I never ordered from them so I don't know about customer service and if you really need for the money to go somewhere I'll take it
Poppa smurf is offline   Reply With Quote
Old 12-01-2002, 11:03 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You might get in touch with Subie Gal, she sells parts at a dealership and if it's available she can probably get you a decent price.
Old 12-01-2002, 11:29 PM   #6
Teamugi
Member#: 7771
Thanks guys.
Poppa smurf: unless you look like a Victoria Secret model or know someone who does, then the money still goes to the car.
Old 12-09-2002, 03:17 PM   #7
WRXerist
Member#: 20235
2006 FX45
I HAVE FOUND THE ONE:
http://www.wrxtra.com/
Click on Catalog and then Oil Temp Sender Plug.
WRXerist is offline   Reply With Quote
Old 12-09-2002, 07:36 PM   #8
Teamugi
Member#: 7771
WRXerist: Thanks! I needed that part. Now I need the sender and all the wiring that would come with it. Do you sell those parts too? Thanks.
Old 12-09-2002, 08:28 PM   #9
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Or just get the part numbers from this thread http://forums.nasioc.com/forums/show...hreadid=268434 and get them from your dealership and save yourself some money. It's like 12 something canadian funds so under 10 bucks american dollars.
Also check out the mounting location they used, a little bit harder to install but you don't have to worry about working around the sensor when you do an oil change.
cheeRS,
Buster
EvasionOfTruth is offline   Reply With Quote
Old 12-10-2002, 01:50 AM   #10
Teamugi
Member#: 7771
EvasionOfTruth: Thanks Evasion. That was a good read. Did you install your oil temp sensor already? If so does the gauge read accurately, even though it is not tap into the oil pan? Last question is still where I can get the sender and one that works with the LaMco oil temp gauge that Subaru uses in its gauge pack.
LA WTB: Oil Temp Sensor for lamco oil temp gauge Yulri Private 'Wanted' Classifieds 0 03-09-2008 09:14 PM
Where to get an Oil Drain plug for oil temp sensor ? (HKS CAMP) Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-27-2004 03:35 PM
WTB!! NEED HELP! Oil Pan Drain Plug w/ Oil Temp Sensor Hotrodguru Texas Impreza Club Forum -- TXIC 5 01-02-2004 12:50 PM
NEED HELP! WTB: Oil Pan Drain Plug w/ Oil Temp Sensor Hotrodguru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2004 10:18 PM
Oil Pressure and Oil Temp Sensor Wrxified Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-05-2003 05:32 PM
