Old 12-01-2002, 10:37 PM   #1
Impulsivegoat23
Member#: 25761
2002 2.5 RS
Alpine White
Default Knock/Det. on startup? ECU stall engine?
I have had a Ganzflow on my 02 RS for a month to a month and a half. Last week I put a Apex'i WRX N1 exhaust (2.5" to 3.0" piping) and then Friday night I put on a Borla header. Now I have a CEL which I'll worry about until Autozone can confirm the Catalyst Inefficiency code. The other night I heard some rattling similar to that Cobreth was asking about, same as him thought it might be the intake tubing hitting the inner fender wall. Then yesterday, when starting up the car I heard the same noise and then it stalled. I assume that the "extra" flow from these parts very well could cause detonation/Knock. Is the clackity sound I heard possibly that and if it was detonation on start-up would the ECU detect it, retard the ignition and in the process cut the engine off? When Autozone confirms/negates the CEL, will the ECU also tell codes on it having detected Detonation? Thanks.
Impulsivegoat23 is offline   Reply With Quote
Old 12-01-2002, 10:46 PM   #2
MattDell
Member#: 16803
Ok, that sounds EXACTLY like what happened to me, but I don't have headers and my car is stalling while driving. Maybe there is some kind of unknown problem with the GDA 2.5RS?
MattDell is offline   Reply With Quote
Old 12-01-2002, 10:56 PM   #3
Impulsivegoat23
Member#: 25761
2002 2.5 RS
Alpine White
That's what I thought when I saw you had an '02 as well. I've heard it twice. Once when it died while starting, and once while driving but it didn't stall the first time I heard it while driving. Just a little more info.....my sound was metal clacking/ pinging sound, and from where I was behind the wheel it sounded like it was right on the other side of the passenger side windshield, like passenger side of the engine bay right around the hood hinge area. By the way my Ganzflow doesn't have a mounting bracket that attaches it where the stock one was mounted, but I haven't heard it "flop around" before the headers neither.
Old 12-01-2002, 11:21 PM   #4
MattDell
Member#: 16803
My Cobb doesn't have any mounting brackets, either, it just kinda rests on the fender and throttle body. The sound I get is coming from the same place you're describing. Do you have a MT? Try going uphill with the RPMs about 1.5 - 2.5K and feathering the clutch. That's when I heard it the most. That, and when I started the engine. Last night I went and checked to see if my Cobb was in the fender or not. It wasn't, and I slipped it back into the fender and slipped the silicone end out a bit more so it wouldn't come out again. Mine has been running like a champ for 50 miles since I did that, but only time will tell. I've still got a CEL, though, but I've had that since before I got the Cobb. I'm starting to think that my friend unplugged something when he installed my Hella horns for me. We installed the horns around where the MAP sensor is and I've had that CEL since then. Man, I need someone to look at my car who has some experience with MAPs. I really don't feel like going to Subaru, my dealer is a PITA.
Engine knock/movement on startup/shutdown radallis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-17-2009 10:53 PM
Funny knocking noise on startup Wheeler Bement Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-01-2004 10:15 AM
Car stalled on startup?????? Crash477 Normally Aspirated Powertrain 9 05-26-2004 10:04 PM
bigger injectors --> stalls on startup? STi-Nismo Dood Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-22-2003 01:36 AM
engine knock on startup rallyho New England Impreza Club Forum -- NESIC 7 01-15-2003 06:59 AM
