12-01-2002, 11:16 PM | #1 |
Member#: 11349
Vehicle:2016 Mustang GT Blue |
No A/C?
Has anyone removed there A/C?
Meaning, has anyone just disconnected the belt. I purchased the GFB Pulley kit and was wondering about just not hooking up the A/C belt. Any gains or losses?
12-02-2002, 11:27 AM | #2 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
maybe 2 hp if your lucky, you wont really feel a difference, cept in the summer time when its hot
Jay McDade |
12-02-2002, 11:48 AM | #3 |
Member#: 11349
ok thanks
12-02-2002, 04:46 PM | #4 |
Member#: 6542
South East
Vehicle:1997 Ver IV silver |
i ran around with mine this way for a while last summer (in FL -- UGH) since the bearing inside my a/c idler pulley decided to implode and make the worst metal on metal scraping noise known to man. so until i could get a new pulley, i just took the belt off.
even on a 1.8L engine, where that 2hp would have been nearly a 2% gain in power all the way around , i was hard pressed to notice a difference, except for the added sweating. |
12-02-2002, 05:47 PM | #5 |
Member#: 13745
Vehicle:2015 STI WRB |
You would also have the benefits of weight reduction if you take out all of the ACs parts such as the condensor..
12-02-2002, 06:52 PM | #6 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
there's not much benefit to be had really
i ran with no ac all on the rally car and there was hardly a difference in weight (maybe 20lbs) and nothing to be had for HP gains... hope this helps Jamie www.subiegalracing.com www.subiegal.com |
12-03-2002, 12:52 AM | #7 |
Member#: 11349
Well, i might disconnect the belt for winter, with the GFB pulleys i just got. I will try it this weekend. Thanks all
12-03-2002, 02:39 AM | #8 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
All I notice are the massive HP decreases when my A/C is running
12-03-2002, 11:43 PM | #9 |
Member#: 13745
Well, if you take the minute gains from removing the AC, coupled with the weight reduction, and you take of any other unneeded weight on the car, it all adds up in the end..
12-04-2002, 12:47 AM | #10 | |
Member#: 11349
12-04-2002, 01:09 AM | #11 |
Member#: 13745
Theres about 200 lbs of stuff that can be fremoved from the car and another 200lbs can be removed by buying lightweight stuff.. A 2580 lb RS with 220 HP would be pretty sick!
12-04-2002, 01:39 AM | #12 | |
Member#: 2272
BAIC
12-04-2002, 01:54 AM | #13 |
Member#: 13745
That would be as bad as my dream car.. My 02 RS weighing in at 2500 lbs with 250 Crank HP N/A!
Help! No interior lights, no radio, no alarm, no temp sensor; NOT fuses | Stray Cat | Electrical & Lighting | 6 | 07-04-2008 02:32 AM |
Finally good looking...56k no no no no no no | 96Imprezadent | Member's Car Gallery | 17 | 04-18-2005 08:19 PM |
UTEC shows NO TPS signal NO MAP, and no air or coolant temps. | jared nelson | Engine Management & Tuning | 4 | 12-20-2004 05:47 PM |
Odd problem, no radio, no clock, no lights... | Mancini | Electrical & Lighting | 0 | 08-19-2003 05:47 PM |
NO, NO, NO I officially have the best GF ever | creature546 | General Community | 11 | 06-25-2003 02:10 AM |
