Old 12-02-2002, 02:22 AM   #1
DOROPPU3127
Member#: 26150
03 IMPREZA WRX
RALLY BLUE
Unhappy Please Help......The car sometimes stalls when I shift to neutral on the road
I have a 2003 wrx with Blitz intercooler and air intake installed, but there is a problem after I stalled these, the car sometimes stalls when I shift the gear to neutral while I drive on the road ( rpm drops to zero and the engine stops)...... so is there any one who knows what the problem is and how to fix it.....Thanks for your help
Doroppu
DOROPPU3127 is offline   Reply With Quote
Old 12-02-2002, 02:56 AM   #2
kaos200
Member#: 2692
Default Re: Please Help......The car sometimes stalls when I shift to neutral on the road
Doroppu
does ur blow off valve vent to atmosphere?
BTW, this is the Normally aspirated forum. maybe a mod can move it for u?
kaos200 is offline   Reply With Quote
Old 12-02-2002, 03:15 AM   #3
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
sounds like its not idling right, not realy a problem with shifting to neutral, just so happens that you notice it when you shift to neutral and it tries to idle.
jasona is offline   Reply With Quote
Old 12-02-2002, 11:23 AM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
i cant move it but ill offer some advice, did you plug the mas air flow sensor back in?
check all your hoses and connections, make sure they are tight and none of them popped off.
do you get a check engine light?
if everything is installed properly, and all the connections are tight, try reseting the ECU, and see if that helps.
Jay McDade
Lincoln/Mercury/Jaguar Tech.
Old 12-02-2002, 11:41 AM   #5
SubaruRallySport
Member#: 22595
2002 2.5 RS
So you installed..... umm maybe thats is your problem. Just joking around.
SubaruRallySport is offline   Reply With Quote
OT Help my friend win contest! Just need you to click on the link! Chewyguru Off-Topic 25 12-18-2008 10:42 PM
Going to the dealer today. Should I switch back to stock on the ECU? EsTeaEye Newbies & FAQs 10 01-10-2008 04:57 AM
Why does my clutch release when I start to push on the peddle? Brooke Transmission (AT/MT) & Driveline 5 11-03-2005 09:42 PM
Please Help......The car sometimes stalls when I shift to neutral on the road DOROPPU3127 General Community 7 12-02-2002 11:22 AM
Please Help......The car sometimes stalls when I shift to neutral on the road DOROPPU3127 Engine Management & Tuning 4 12-02-2002 11:18 AM
