Old 12-02-2002, 03:51 AM   #1
danci1973
Member#: 19018
1995 Legacy Wagon
Lightbulb Twin Throttle Body
Has anyone ever tried (or thought of) using two throttle bodies - one for each half of the engine??
It seems possible, placing the TBs over the heads, facing each other. This would require new runners (or intake 'half manifolds' ) and some new intake piping. One TB could do without TPS, which could in turn be used to connect both throttle plates together.
Here is a sketch of what I have in mind:
Notice how short those runners could come out...
Comments, please...
Thx, D.
danci1973 is offline   Reply With Quote
Old 12-02-2002, 04:26 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
good luck designing a likage that will work with both throttle bodies and you will need to get a stand alone system in order to properly tune the motor since you have just theoretically completely changed the air metering system.
jeremy
Old 12-02-2002, 04:59 AM   #3
danci1973
Member#: 19018
1995 Legacy Wagon
So far, making new runners seems to be the hardest part, together with getting a cheap/free spare TB.
Linkage doesn't seem all that complicated - by removing the TPS on one TB I would get a rotating axle which could be used for linking to the other TB.
Are you sure? My car has a MAF, which would still be at the end of the intake, so all the air would still flow through it.
If I get a second TB and someone to make new runners (or 'half-manifolds' ), I'll try it out.
D.
Old 12-02-2002, 08:28 AM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Sounds like a hell of a lot of work for no real particular reason other then just doing it..........cool.
In all honesty......I wouldn't waste your time or money....if you were looking at doing this for performance gains......there's much cheaper means of getting more hp then what this would do.
I'd probably compare this to some of the older rods with triple deuce carbs..... Sure they can crank out the hp, but are an incredible pain to tune, and always have some sort of issue or problem.
Legacy777 is offline   Reply With Quote
Old 12-02-2002, 10:13 AM   #5
danci1973
Member#: 19018
1995 Legacy Wagon
Considering all the talk about how bad the stock manifold is, I thought it was a good idea... Dang...
D.
Old 12-02-2002, 10:37 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
D.
why does everyone think the stock manifold is so bad?? i mean it's not all that restrictive, sure it needs a lil bit of positive pressure but you will never net gains off a NA manifold like people seem to think. a very mild port job would increase the airflow quite a bit. anyhow good luck if you do it, i wouldn't though.
jeremy
Old 12-02-2002, 05:35 PM   #7
guitaro
Member#: 30010
yea it would run lean if both throttle bodies did not have Mass airflow sensors on both intakes. It might work if you had Manifold absolute pressure (MAP) sensors.
guitaro is offline   Reply With Quote
Old 12-02-2002, 05:57 PM   #8
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
i would do it if i were you, just because it would be cool.
jasona is offline   Reply With Quote
USDM Throttle Body, JDM Throttle Body, USDM IACV scooterforever Engine/Power/Exhaust 0 08-19-2006 05:38 PM
2.0 Twin turbo throttle body versus 2.2 NA throttle body reddevil Pre-2002 Factory Turbo Powertrain 3 06-23-2006 01:06 PM
IACV sensor, Throttle body sensor, or entire used throttle body! annointed Private 'Wanted' Classifieds 1 05-15-2006 06:11 PM
Sticky Throttle/Throttle Body Cleaning - Warrenty? 85258 Normally Aspirated Powertrain 7 10-17-2003 08:45 AM
Remove Throttle Shaft from Throttle Body WRX03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-16-2003 05:14 PM
