Old 12-02-2002, 10:09 AM   #1
IggDawg
Celebrity Guest Star
Member#: 10648
2002 Escort... D:
Mostly kind of white
Question Borla headers or S-AFC?
I'm looking at 300-ish to blow on christmas goodies. Would it be best to get a AFC or just headers? I'm thinkin the AFC wouled be the best way to go, but headers sound like a good idea too. Also, I'm going turbo eventually, and IIRC a AFC is good to have around for that. What do y'all think?
-IggDawg
IggDawg is offline   Reply With Quote
Old 12-02-2002, 10:44 AM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
if you are going turbo, get the S-AFC....
if you are going N/A, get the headers....
I have both btw
~Brian
rhdude is offline   Reply With Quote
Old 12-02-2002, 11:00 AM   #3
IggDawg
Member#: 10648
2002 Escort... D:
Risking sounding like a n00b... Which one will give me the most gains if I'm stock other than intake? God... it hurt even to ask. Normally I'd side with headers, but from what I know our WOT runs a pitiful fuel map, and with a 3 inch intake, 3 inch airbox mod, and TB mod, I'm thinking a modified fuel delivery might benefit me a little.
-IggDawg
Old 12-02-2002, 11:13 AM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Actually, unless you like sound the Borlas are not worth the $$ (they are the lowest power producing scooby header). The S-AFC will help somewhat (couple of ponies) unless you're pretty highly modded (or having A/F problems like leaning out). For similar money you could look at a flywheel or clutch or pullies. The S-AFC is a good idea for larger boost applications but for smaller (RHB5, TD03 <6 psi) a RRFPR, parallel fuel rails and a walbro pump usually do the trick nicely. One other thing to consider especially if you're going turbo would be an ITC, more control over the timing = good! Plus the OE ECU doesn't "learn around" timing adjustments.
Old 12-02-2002, 11:26 AM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
I would say SAFC, but then you will need a way to tune the SAFC, you cant just punch in some settings. Do you have an EGT and A/F gauge? Or an AWD dyno close to have it tunned?
I too feel the headers just make noise, I dont think anyone has gotten any substantial gains from headers on a scooby.
Jay McDade
Old 12-02-2002, 04:00 PM   #6
Silverscooby27
Member#: 9124
2013 Mustang GT/CS
2013 Ford Focus ST
Between Headers and AFC: headers. If you think Borla headers won't do much, AFC won't do squat if all you have is an intake, especially if you have no way to tune it (i.e. an A/F gauge, EGT gauge and an AWD dyno). Stock ECU can handle the mixture just fine. In fact, there really isn't all THAT much to tune A/F-wise even with a full aftermarket exhaust and intake. If anything, my car was running too rich.
Silverscooby27 is offline   Reply With Quote
Old 12-02-2002, 04:01 PM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
That's why I suggested an ITC, more to be gained than tweaking air/fuel mix. You may also consider [flame suit on] a ProECM. I have one, you can read my review on scoobymods.com but I can say it was $$ well spent... and rumor has it there is a new firmware update (v3.0) coming out real soon. [/flame suit on]
Old 12-02-2002, 04:09 PM   #8
Silverscooby27
Member#: 9124
2013 Mustang GT/CS
2013 Ford Focus ST
I've got the ProECM too, and like it as well. In fact, I bought one, gave it to a friend, and then bought another.
Old 12-02-2002, 04:22 PM   #9
IggDawg
Member#: 10648
2002 Escort... D:
Can I be your friend
-IggDawg
Old 12-02-2002, 05:00 PM   #10
Silverscooby27
Member#: 9124
2013 Mustang GT/CS
2013 Ford Focus ST
Point was that if the question was, "Would I buy it again", the answer would be "yes".
How many Iggpoints would the ProECM be worth?
Old 12-02-2002, 08:47 PM   #11
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2008 STi DGM (3rd
STI) prev 05 STi (white)
eleventy bajillion...
boy, how and where can we get a firmware upgrade?
DanzBorin is offline   Reply With Quote
Old 12-03-2002, 12:58 AM   #12
Impulsivegoat23
Member#: 25761
2002 2.5 RS
Alpine White
This was my exact quandry. S-AFC or Borla Headers. I had just put on my 3" intake and Apex'i N1 Exhaust. Either way I had planned on getteng the other soon. I went with header. Now I have to buy the CEL fix. Anyone know if I'll still pass emissions after putting on the CEL wire in fix? Will the ITC be a better idea for my next purchase? What kind of gains will it produce in comparison with the AFC? I have heard about our computers learning around the S-AFC's anyways. I just need to find a place for all these gadgets on/in my dash...hehe.
Impulsivegoat23 is offline   Reply With Quote
Old 12-03-2002, 09:35 AM   #13
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Danz, not sure if v3.0 will fit into the ProECM box or if its just a new chip release... trying to get more info from the company.
The ITC will allow timing control which is a must have for tweaking power and a must have if you may go F/I in the future. The ProECM provides timing control and fuel trim modification but it is not user tunable. Price wise the S-AFC and the ITC are both more expensive than the ProECM/TC-II but they are user programable (and have bling bling factor). Yes, the 00+ ECUs will learn around the S-AFC but, realistically, you're only going to see a couple of ponies anyway (unless you have some serious mixture issues). I'm also trying to ferret out the details on the Greddy Emanage and why it has not worked with the subaru ECUs b/c for the money it is by far the most promising piggyback out there.
Old 12-03-2002, 09:40 AM   #14
IggDawg
Member#: 10648
2002 Escort... D:
well in any event, the headers don't do a heck of a lot either do they? I'm looking mostly for sound a little bit nicer of a high end.
-IggDawg
Old 12-03-2002, 09:52 AM   #15
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Igg, I've got a complete custom exhaust (headers, high flow, cat back) that only cost me ~$300 including muffler. PM me if you want more details on how to have one made locally.
Old 12-03-2002, 10:17 AM   #16
RaceCarRiot
Member#: 6542
1997 Ver IV
if you're going FI, i would just save my money, and figure out what i need at that point in time. i would go ahead and get the headers...you'll see more of a gain than a SAFC alone (for now anyways), and at least they'll still be useful once you turbo the car (better spool up), unless you go the 'factory turbo' route, and need to swap the crossmember.
the chip would be a good choice as well as there really aren't any drawbacks other than having to run higher grade gas to take advantage of it...but if you're going FI, then you're going to need user control of your timing.
RaceCarRiot is offline   Reply With Quote
Old 12-03-2002, 01:18 PM   #17
pdlindor
Member#: 7446
2002 Impreza RS
2009 Forester Limited
Correct me if I'm wrong, but I was under the impression that the S-AFC was still useful at WOT on the 00-02's, which is where you'd want the adjustments made anyway.
I have also heard that the S-AFC can be used to reduce/eliminate the WOT bog caused by running uber-rich.
~Paul
pdlindor is offline   Reply With Quote
Old 12-04-2002, 01:37 AM   #18
joefocker20
Member#: 13745
2004 STI
Well, search for some of Patrick Olsens threads, he gained around 7 HP from tuning his S-AFC.
joefocker20 is offline   Reply With Quote
Old 12-04-2002, 11:32 AM   #19
Swano
Member#: 19114
2002 2.5TS
Blue Ridge
Joe, Patrick has i/h/e and cams....
Phil =)
Swano is offline   Reply With Quote
Old 12-04-2002, 02:23 PM   #20
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
I thought that in a previous discussion it was proven that the whole ECU learning around the S-AFC was a myth. I don't remember the thread, but I am sure a search could bring it up.
-Wes
RebelINS is offline   Reply With Quote
WTB: Borla Headers or replica headers mattlett14 Private 'Wanted' Classifieds 0 06-23-2006 10:21 AM
Borla Headers or TMIC blkwrx02 Factory 2.0L Turbo Powertrain 19 10-05-2005 10:55 PM
borla header or a catback exhaust rawrFERNY Normally Aspirated Powertrain 10 06-24-2004 12:28 AM
Borla header or Blitz intake cre Factory 2.0L Turbo Powertrain 6 08-08-2003 11:25 AM
borla header or high flow cat jdsimpreza Normally Aspirated Powertrain 17 12-07-2001 02:39 PM
Message Board Statistics All times are GMT -4. The time now is 08:01 AM.
