Old 12-02-2002, 01:34 PM   #1
sen
Member#: 1216
2007 WRX
WR Blue
Question Random Missfirre
As The temperature gets colder I have been having Missfire codes poping up more often. Some times I get Cylinder #2 or Cylinder 2,3,4. I have Cobb heads and cams with an underdrive pullt set on a 98 2.5RS. The ligth does not flash it just comes on and resets itself after a few cycles of driving.
At idel the light are running dimmer. When I hit the gas in park the head lights go to normal.
Any ideas on a fix besides removing the underdrive pully, which was a bitch to get on an Automatic.
SEN
sen is offline   Reply With Quote
Old 12-02-2002, 03:20 PM   #2
outback2.5HO
Member#: 15135
95 GF WRX
The dim lights are definately from the pulley.
As for the misfire codes, does your car run badly when the check engine light is on? If the car wasn't put together properly or the belt has slipped (cam timing off) that could be a problem also.
outback2.5HO is offline   Reply With Quote
Old 12-02-2002, 03:23 PM   #3
sen
Member#: 1216
2007 WRX
WR Blue
Post ?
Subaru put it all together. The car runs great 24 MPG and 21MPG around town.
Old 12-02-2002, 03:53 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
welcome to the world of aftermarket parts do you have an intake yet?? if you don't get one, i get a random misfire on cylinder 2 from my flywheel the intake has cured it and has only happened 3 times since then, that was about 5 months ago. I got it twice in the past week because of the fuels starting to get dilluted and such....good luck
Jeremy
Old 12-03-2002, 03:57 AM   #5
JSiwek
Member#: 14909
Ever since I put a light flywheel in my car I've had a recurring CEL come on at 74 mph. Yeah, only at 74 mph, and it blinks. Normally blinking would make me really nervous, but every time I've had the code pulled it tells me some cylinder(s) was/were misfiring, but I can't feel, hear, or in any other way detect that there is actually any sort of misfire going on whatsoever while it's blinking. On top of that, the info stored in the ECU never makes any sense. It will say that my car was going XXXX rpm's and XX mph (when I know it happens at only 74), and with the gear ratios that I have I can never even go the speed it says at the rpm's it says! Last time it said it occured at 250 rpm... the car wont even run at 250 rpm. It's been written off as a computer glitch, and I'm happy with that.
Jeremy
JSiwek is offline   Reply With Quote
WTB random clips, bolts.random small parts. i have a bugeye. Parting out?come in! subizzo02 Private 'Wanted' Classifieds 3 09-30-2009 09:13 PM
Random IMs from a random person who wants me to call a random number TimStevens Off-Topic 33 09-15-2009 05:55 PM
Skype IM from random person: really random, or am I being perverted justice'ed? poison Off-Topic 5 03-04-2007 05:11 PM
A random quote from a random website Reciprocity Off-Topic 9 12-04-2005 10:07 AM
Help: Random CEL and Random Shut Off FatStraws Texas Impreza Club Forum -- TXIC 38 07-22-2005 08:17 PM
