Old 12-02-2002, 05:25 PM   #1
WRXVII
Member#: 15854
VF34'd...
Exclamation Perrin crank pulley problem
Since Perrin crank pulley has been installed, I hear metal screeching sound from the belt/alternator/crank area. It sounds sort of like whining sound similar to metal screeching. Could this be due to overly tightened belt? this happens when the weather is cold and gets better as engine warms up. Should I loosen the belt?
Thanks in advance
Tim
WRXVII is offline   Reply With Quote
Old 12-02-2002, 06:03 PM   #2
atomicapples
Member#: 12626
02 2.5 rs
when i got my pulley installed (vishnu) i pushed down on the longest part of teh belt. it went down about an inch (until it didnt want to go anymore). maybe you can loosen it. did you tighened the pulley enough?
atomicapples is offline   Reply With Quote
Old 12-02-2002, 09:02 PM   #3
WRXVII
Member#: 15854
VF34'd...
I just loosened it.... will have to wait until tomorrow morning...
Old 12-02-2002, 10:00 PM   #4
koloumb
Member#: 28268
2002 WRX Sedan
How many miles are on your car?
The most likely canidate is a belt that's too loose if the car has low mileage. When installing a new crank or belt, you want to make sure the adjustments are done while everything is cool.
There should be a procedure on how to adjust the belts in the manual included with the car.
_Owen_
koloumb is offline   Reply With Quote
Old 12-02-2002, 10:49 PM   #5
WRXVII
Member#: 15854
VF34'd...
my car has about 29000 miles on.
Old 12-03-2002, 12:02 AM   #6
koloumb
Member#: 28268
2002 WRX Sedan
Belts never been changed? Look at the part of the belt that contacts the pulleys - is it shiny? A loost belt with a shiny surface will surely cause that annoying squeal..
Just follow the procedure in the manual and you should be fine as long as the belts don't show any signs of cracking...
_Owen_
Perrin crank pulley vs. GFB 2 pcs pulleys gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-21-2008 06:37 PM
FS: Socal: Perrin crank pulley, Perrin Fuel Rail Kit, Injen Cross-Pipe. RSXiMUS Engine/Power/Exhaust 7 04-30-2008 05:54 PM
I will trade my perrin crank pulley for a stock crank pulley NITROS Mid West Subaru Owners Club Forum -- MWSOC 8 07-21-2006 10:51 AM
Perrin Crank Pulley Vs Unorthodox Racing Ultra S lightened underdrive crank pulley west_minist Normally Aspirated Powertrain 3 02-21-2005 11:56 PM
Perrin Crank Pulley problems Kitt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 01-13-2004 12:42 PM
