Old 12-03-2002, 10:43 AM   #1
RaceCarRiot
Member#: 6542
1997 Ver IV
Talking proECM + 100 octane race fuel = wheeeeee!
just thought i'd try this out of curiosity, but i was running on fumes, and stopped at a gas station that sells 100 octane race gas just to see how the car would react to a few gallons.
according to the 'spirited acceleration' runs thereafter, i gained an additional 5-6ps at redline (HP = PS x 0.986, as i recall), consistently pulling 115ps with ease. what was most impressive, is the car seemed to be reaching it's toruqe peak MUCH sooner, peaking and flattening out around 3600rpm, and putting out around 85ps, more than a stock 1.8 wound out to it's 5700rpm peak.
also, even with the mere 3 gallons i put in there, and how hard the car was driven, i managed to go a little over 100 miles without incident before chickening out and filling the tank.
-adam-
RaceCarRiot is offline   Reply With Quote
Old 12-03-2002, 11:42 AM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
The lower the octane, the better for a N/A car.... Of course you don't want to go below 87.
rhdude is offline   Reply With Quote
Old 12-03-2002, 12:42 PM   #3
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
Why is lower octane gas better for NA?
cRayZee is online now   Reply With Quote
Old 12-03-2002, 01:09 PM   #4
rhdude
Member#: 6637
it's not a refined so it has more "power" left in it. It is stable enough to not cause detonation, which is one reason why we don't use anything below 87, because it would literaly blow our motors up. there are plenty of threads about this topic, do a search if you want even more info
~Brian
Old 12-03-2002, 01:21 PM   #5
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
ok, cool..just wanted to know what you meant by "better"
Old 12-03-2002, 01:31 PM   #6
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Why would the creator of this thread claim gains on 100 octane gas if the best kind of gas for a N/A motor is below 90?
DrBoy01 is offline   Reply With Quote
Old 12-03-2002, 01:48 PM   #7
RaceCarRiot
Member#: 6542
1997 Ver IV
because the chip will advance the timing and tweak the fuel map to take advantage of the higher octane.
on a stock car, you wouldn't see any gain.
did anyone read the title of the thread?
proECM + 100 octane race fuel...
Old 12-03-2002, 01:49 PM   #8
reidski
Member#: 13333
2001 RS Sedan
Black Diamond Pearl
Default I like 87
For months I had always used 92 or 93 octane in my 2.5 RS. But one day I decided to throw in some Exxon 87 when I was running really low on gas. I'd say it really likes the 87 much better than the 93. Throttle responce seems better. Just have a Ganzflow CAI and Amsoil air filter.
Just my 2 cents.
Ken
reidski is offline   Reply With Quote
Old 12-03-2002, 02:00 PM   #9
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
Default Re: I like 87
Just my 2 cents.
Ken
That's probably cuz the stock ecu couldn't take advantage of the 93 octane by advancing the timing more.
Old 12-03-2002, 03:04 PM   #10
RENEMARTIN
Member#: 29599
2001 IMPREZA RS
BLUE
So would a PROECM and 93 or 87 be better
RENEMARTIN is offline   Reply With Quote
Old 12-03-2002, 03:46 PM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Proecm + 93, otherwise it wont do anything.
Old 12-03-2002, 04:52 PM   #12
RaceCarRiot
Member#: 6542
1997 Ver IV
yeah, you have to run premium all the time, or else the chip won't do a whole heck of a lot. but as long as you can resist keeping your foot out of it ALL the time (heh), your mileage should be improved enough to offset the few additional bucks a tank.
having said that, unless i'm cruising on the highway, i usually run my car pretty hard all the time...all of my driving is spirited. between keeping the engine on the boil (so you'd never know it was a 110hp car, *chuckle*), rev-matching on all my downshifts, constantly downshifting and engine braking, etc. i still manage ~25mpg in town on a tank of 93.
Old 12-03-2002, 06:21 PM   #13
rhdude
Member#: 6637
I had a proecm, dyno'd... does'nt do crap....
all it does (IIRC) is make the ECU run off the cold coolant map, it has NOTHING to do with octane numbers....
Why would he claim this? its all psycological....
Now, prove me wrong, go get me some dyno figures to prove it.
When I took off my WRC decals my car lost 10hp becuase it felt slower! no I swear, and if you say it did'nt you're wrong
~Brian
Old 12-03-2002, 07:30 PM   #14
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
~Brian
were you using 87 octane gas? Since the lower octane is better?
Old 12-03-2002, 08:18 PM   #15
rhdude
Member#: 6637
no!... 93, cause of the turbo
Old 12-03-2002, 09:00 PM   #16
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
I really don't want to get into this discussion again, because it has been posted to death about in the past. I thought the whole theory was that running off a cold coolant map causes timing advance. That is why higher octane gas would help, because it could deal with advancing the timing a lot. I am not saying that it effectively works, or is worth the money, but I thought that the theory behind it.
-Wes
RebelINS is offline   Reply With Quote
Old 12-03-2002, 09:02 PM   #17
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
well, w/ the 93 octane and turbo, i don't know what the proecm would do. shouldn't really advance the timing more All i know is that for force induction purposes all it does is it has its own voltage clamp and supposedly lets the ecu learn faster. But once you're on boost, all the stock ecu would see is that you're at maximum MAP and will run off the proper fuel map. d0h But you have a MAF-based car ,so i dunno what the proecm does for your car
just babbling here
-vic
Old 12-03-2002, 09:30 PM   #18
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
I had one a sold it a month later since I didn't see any change and yes i was running 93 but others had good results. But what about the knock sensor since it advances timing is there any conflict?
Poppa smurf is offline   Reply With Quote
Old 12-03-2002, 10:31 PM   #19
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
Just because a car is NA doesn't mean you should use the lowest octane gas. A NA engine can produce enough heat to cause detonation problems. Try putting 87 octane in an S2000 and see what happens.
95% of 2.5 RS's in the world should use 87-89 octane gas though.
Dolphin Overton is offline   Reply With Quote
Old 12-03-2002, 11:03 PM   #20
Storm
Member#: 5218
96L Most Over-
Developed Beater
Sure is alot of bad information floating in this thread....
Old 12-03-2002, 11:23 PM   #21
rhdude
Member#: 6637
sorry, I meant to say for RS's..... becuase all motor drags cars use race gas, but that does'nt mean you should... lol..
And I had the ProECM a few weeks before the turbo...
Old 12-04-2002, 08:53 AM   #22
RaceCarRiot
Member#: 6542
1997 Ver IV
if you're running a turbo, i doubt the chip is going to do much for the car, since you're generally going to need to back the timing off...
i didn't mean to spark another debate as to whether the chip works. i can give you a number of reasons as to why aftermarket intakes don't do anything...but despite the fact that numerous people are using them anyways, i don't make it my life's mission to rain on their parade.
i just thought i'd note that the chip DOES indeed show greater benefits from the highest octane gas you can put in the car. that is all.
all readings were taken from an apex RSM, not the boo-tay dyno™. as accurate as a set of rollers? no, of course not, but more so than a g-tech or anything else similar that normal people have easy access to.
Old 12-04-2002, 09:21 PM   #23
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Racecar
Hey Racecar,
I felt the very same way as you do. I pumped 110 octane gas in my XT6 at the dragstrip and was using nitrous (that leaned terribly). The throttle response was awesome and the car felt great. The 110 octane was put on the already high 93 that I normally run and I DID feel a difference and it felt great. The car became quieter and felt smoother BUT........BUT.......BUT *Suspense*
I won't comment. You have to run your car on the strip to see where I'm coming from with the 'but'. I tested on several runs on 3 different track nights. Good luck!
Kevin Thomas is offline   Reply With Quote
Old 12-05-2002, 12:36 AM   #24
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Racecar,
Just in case you don't feel like sparking another debate...
can you PM me the reason why aftermarket intakes are worthless?
Old 12-05-2002, 08:34 AM   #25
RaceCarRiot
Member#: 6542
1997 Ver IV
Default Re: Racecar
Originally posted by Kevin Thomas
...and I DID feel a difference and it felt great. The car became quieter and felt smoother BUT........BUT.......BUT *Suspense*
suspense???
did your car blow up?
didn't take it to the strip, but yes, in addition to this, the car felt much smoother too...
100 octane oxygenated race fuel 06-wrx-tr Motorsports 10 04-07-2009 12:26 PM
100+Octane unleaded fuel near Central FL? 1/500yellowwrx South East Region Forum 17 10-27-2008 11:56 PM
100 octane race gas map for sti accessport mpower22 Engine Management & Tuning 3 08-11-2004 08:53 AM
long term damage from using 100 octane race gas? casualsurfer Newbies & FAQs 5 05-08-2004 05:02 PM
CAMII 110 octane race fuel Brewmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-07-2002 09:53 PM
