#1 |
Member#: 14254
VIC
Vehicle:2005 Impreza WRX STi Aspen White |
I just purchased a PDM intake, ive read that some 99 RS owners have blown their maf sensor after installing the intake.
the new age wrx has been mentioned a few times also. Just wanna hear from some 02/03 owners if they have had any problems with this intake. thanks in advance, David.
#2 |
Member#: 20395
Vehicle:87 VW "TSD" Golf Past 2002 & 2003 BRP TS |
Hey David, currently at 18000km, and have been running it with a K&N filter since 5000km with no issues.
Don't expect any major performance increases (would add more when combined with a cat-back and cams), but it makes the engine purr at higher RPMs. If you want to see it installed and hear it on an 02 TS auto, let me know and we can meet. PS - most of the MAF issues on the RS related to an older style MAF that was recalled. In addition, the PDM CAI doesn't require the removal of the stock airbox, which was also another cause relating to failed MAFS. Doug |
#3 |
Member#: 9191
Vehicle:2002 Impreza 2.5TS Blue Ridge Pearl |
00-03 use a MAP, not a MAF.
#4 |
Member#: 14254
VIC
Doug,
Its good to hear that you have had no problems with it all the way to 18000km! I dont expect it to give me good gains, i like it for the noise!! anyway, i will be getting my k&n filter tommorow. ANother question to you is.. I took a look under the hood and the fender gap didnt look very wide, i dont see how i can put a filter in there without taking off the front quarter panel. if you can give me some info on how you put yours in, that would be very helpful! thanks. |
#5 |
Member#: 4674
Vehicle:2004 Toyota Vitz Black Black Black! |
er... K&N filter goes in the air box, you're talking about a cone filter, and I don't think you should be using that with the PDM intake...
#6 |
Member#: 14254
VIC
oh... sorry i dont know much about this stuff.
thanks, ashtaron14. |
#7 |
Member#: 66
Vehicle:2002 Impreza WRX Britney Edition |
there are no more maf problems post MY99 as far as i know. =)
#8 | |
Member#: 4674
#9 |
Member#: 155
VIC
Vehicle:01 RS Coupe/Silver 00 SiR/06 ZX-6R |
If u want noise, get an open air intake or short ram.. or whatever they call it this week. Those are the ones that use cone filters.
#10 |
Member#: 20395
Thanks Bruno, I wasn't aware of this.
David, pics of the CAI installed (and stock intake you remove) at the following link half way down page 1. http://forums.nasioc.com/forums/show...ghlight=intake Part number for the K&N for the TS is 33-2154. |
#11 |
Member#: 14254
VIC
thanks dudes!!
Doug, i think thats the one i ordered today at lordco. Thanks for the part number. damn that injen one looks so sweet!!!!! does the injen have a cone filter or no? Ooter: that pdm one looks dope in those pics!! |
#12 |
Member#: 20395
The Injen uses a cone filter, therefore the stock air box has to be removed. When researching, I decided to go with PDM for the fact it is less money, and that by removing the factory airbox you may run into further possibilities of warranty claims being denied.
Before you install, you should understand that any mod could cause certain warranty claims being denied if the mod is proven to be the cause of a fault. The PDM CAI does however require less changes to the factory setup than the Injen style intake. Pic of the Injen, but not the exact model for the RS/TS. http://www.overboost.com/obs/product.asp?pid=19891 |
#13 |
Member#: 11118
VIC
Vehicle:2002 2.5 TS Aspen white |
I have been using injen form March 02 no problem
injen have a cone filter, it goes right behind the foglight in the bumper BTW much better than PDM |
#14 |
Member#: 14254
VIC
what kind of damages can a CAI cause?
only thing i can think of is water getting through but the pdm intake pipe is placed at a fair level... hopefully no water will fly up from the little bumper holes and into the pipe.. |
#15 |
Member#: 20395
Water is the main issue, but I have no evidence of water getting in and I have checked after heavy rains and driving through deep puddles.
The stock snorkel has a few chambers that direct water that may get by in to a small drain hole at the bottom. The PDM is a straight pipe with no where for moisture to escape if it does get in. I figure even if a bit of water did get in, it would have to get by the intake (which gets very warm from the engine heat) and through the air filter before causing any damage. I don't see it being a concern at all, but the possibility always exists. |
#16 | |
Member#: 14254
VIC
i have read a few reviews and havent read anything negitive on pdm's intake, so i thought why not. |
#17 |
Member#: 20395
On another topic, my thoughts are the extra cash could be much better spent on a Whiteline rear 18-22 swaybar with brackets and links. So far, the swaybar is the best spent $$$ on my TS.
AllWheelDrift, thanks for the swaybar preaching!!! ![]() |
#18 |
Member#: 11118
VIC
I get it about 450 with tax
Edit: keep in mind that is from March and I get it from Bavaria |
#19 |
Member#: 19332
I'm a noob when it comes to mods and such but can't you cut the PDM intake in half so you can fit an AEM by pass valve between the 2 halves?? It seem like a good idea.
#20 |
Member#: 18247
Vehicle:90 R32 Skyline GTS-T Type M |
yes a bypass valve is a good idea just in case of hydrolock ,the chances of getting a snorkel full of water is rare ,butt could still happen.
those weapon R short intakes are pretty sweet too |
#21 |
Member#: 14254
VIC
ok, i installed my pdm intake today.
went for a drive afterwards and noticed there isnt much of a difference!? it gets a tiny bit deeper after 3k rpm. I didnt put in the K&N drop in filter, is there a big difference if i put in the new filter? |
#22 |
Member#: 19332
In general, getting an intake alone don't do jack all. Since you're changing the breathing characteristic of the engine, you need to get adjustable cam gears and new exhaust to tune it. In some case, you may make the engine weaker.
| Thread Tools | |
| Display Modes | |
| WTB: 02/03 WRX stock air intake or trade for Injen cold air intake | limpstick | VIC Private Classifieds | 17 | 02-16-2007 01:46 AM |
| wagon owners with Prodrive springs please read | randolph-rs | Brakes, Steering & Suspension | 8 | 04-21-2003 04:48 PM |
| Owners of TurboXS uppipe please read | cwb124 | Factory 2.0L Turbo Powertrain | 1 | 08-19-2002 04:51 PM |
| Attn: Anyone with WR intake please read: | Rimmie | Technical Forum Archive | 11 | 06-08-2000 12:55 AM |
