Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 12-04-2002, 08:04 AM   #1
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Have a Nice Day? Good Morning.. Is it normal for the clutch pedal to have morning stiffy?
Hey guys good morn.,
Is it normal for the clutch pedal to be stiffer in the morning, and also, when I depress the clutch the sound changes(there is a slight whine that goes away) and I can here the load on the engine change and hear the rpms dip down(just minutly) and back up when I put push pedal in and out. What the dilly yo?
Paul
PaulRex is offline   Reply With Quote
Old 12-04-2002, 08:10 AM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
ttt and bump= to the bump!
Old 12-04-2002, 08:26 AM   #3
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
Don't know about the stiffness, shouldn't be that much difference. The noise/whine difference is a bearing noise in the transmission. When the clutch is out in neutral, all the bearings in the transmission are spinning. When you put the clutch in, they all stop. If the noise isn't loud and is primarially when it is real cold outside, I wouldn't worry about it. Your indicating that it is real cold by saying that the engine speeds up or slows down. With the clutch out and all the transmission oil real cold, it will put a drag on the engine and you will hear the RPM difference.
rallynutdon is offline   Reply With Quote
Old 12-04-2002, 08:59 AM   #4
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Sounds good.. I havn't changed my clutch fluid yet and I'm at 35k miles. It's not low or anything though, but maybe that would change the feel in the morning. I'll try and change fluid sometime in january..
You seem to have a pretty good grasp of the sit. though, thanks.
Paul
Old 12-04-2002, 09:05 AM   #5
Edvig
Member#: 16147
no more turbo
05 Legacy, 11 Outback
Paul,
I've always found that the car generally speaking is a little tighter when it's cold. Things go back to normal when the car has a chance to warm up. I've been noticing this too, since this is our first real cold spell.
Edvig
Edvig is offline   Reply With Quote
Old 12-04-2002, 09:14 AM   #6
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
The stiffness is because the fluid is cold. When the fluid gets cold, it gets thicker. Yadda yadda yadda.
P.
Pinochle is offline   Reply With Quote
Old 12-04-2002, 12:41 PM   #7
18FOREVR
Member#: 23951
I'm a Vivid Victim!
'03 WRX - WITH NO SPOILER
Talking
I still get a morning stiffy once in awhile. As for my car it's like my body - creaks and groans when I first start up but loosens up as I start moving around. When it's cold the fluids get a little thicker, as the car gets warmer the fluids get back to their normal consistency and all is right with the world. Warm her up for a few minutes as the weather gets colder.
18FOREVR is offline   Reply With Quote
Is it normal for a 6 speed to have foamy oil ElJefe Transmission (AT/MT) & Driveline 8 12-03-2004 12:08 AM
is it normal for the rear end to be squirly? blackie Brakes, Steering & Suspension 18 04-16-2004 08:04 PM
Is it normal for the lights to dim this much? SubaruImpreza_power Newbies & FAQs 2 10-30-2003 04:59 PM
Is it normal for the revs to drop so quickly in neutral? Zoso Transmission (AT/MT) & Driveline 2 06-16-2003 06:41 PM
Is it normal for the steering wheel to vibrate while braking? Hazdaz Brakes, Steering & Suspension 34 02-07-2003 11:30 PM
