Old 12-04-2002, 11:22 AM   #1
Qbushido
Member#: 17120
2004 04WRX STi 99 RS
sold and MBP, SQC# 33
Default Oil spray? PCV Valve?
Do our cars have PCV valves? I'm having some issues with my car and a friend who is a well versed GM mechanic mentioned something about a PCV valve, I dont even know if our cars have those. Do we?? below is a link to a description of my issue
Patrick's car hurtin
Qbushido is offline   Reply With Quote
Old 12-04-2002, 11:41 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Yes you have a PCV valve.
The oil you are seeing is most likely coming from the oil breathers on the valve covers & crankcase breather below the intake.
It is normal to get some oil mist. It's usually sucked back in the intake and burned.
The PCV valve helps this whole process and is basically a check valve, and will open & close depending on vacuum conditions.
If you pull the PCV valve off, and shake it....it should make a noise & you should feel the plunger inside move around. If it doesn't, it's most likely bad. Just get a new one....they're like 5-8 bucks at your local autoparts store.
Legacy777 is offline   Reply With Quote
Old 12-04-2002, 11:43 AM   #3
Qbushido
Member#: 17120
would that explain the slight burning smell when I get out of the car and/or the light smoke I saw for the first time monday?
Old 12-04-2002, 12:47 PM   #4
rhdude
Member#: 6637
2009 Acura MDX Sport
hum light smoke? out of the hood area I'm geussing?
I had my Crankshaft and front Camshaft seals replaced at 70k miles. It's a common problem in subaru's for oil seals to go bad. I'd bring it by the dealer just to see what they say. If you are comfortable working on your car, then pull the fans, and timing belt covers off, and visualy inspect the seals for oil leakage. Also ask them about a leaky oil pump.
~Brian
rhdude is offline   Reply With Quote
how to figure out oil leak? Rear oil seals? PCV valve? kirbykirb Legacy Forum 11 03-28-2011 09:21 PM
Oil in PCV Valve? lanz0r Normally Aspirated Powertrain 3 02-13-2010 08:54 PM
Why do I need a PCV valve or an oil seperator? andys Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 95 12-23-2009 09:33 PM
Burnt Oil on turbo, leaking PCV valve? Achilles38WRX Warranty Issues & SOA Problems 3 03-26-2002 08:24 PM
PCV Valve Replacement richeich SVX Forum Archive 2 06-26-2000 06:53 AM
