Old 12-04-2002, 03:53 PM   #1
Bumsarama
Member#: 3137
2005 STi
WRB Nukabe/Cusco/Carbotec
Unhappy Need Help W/ Hesitation
Occasionally when I stomp on it, especially midturn, the car all of a sudden jerks, and doesn't have power for a split second, if I stay on it, it will start to violently jump. If I lay off the gas and then back on it, everything is ok. I have about 44k miles on my car and still have yet to change the spark plugs. Could it be the fact that I need new spark plugs, or could be it be something else. I installed a Ganzflow about 3 weeks ago. Prior to that my car was not doing this as often as it does now. But even back then it would do it.
Bumsarama is offline   Reply With Quote
Old 12-04-2002, 04:32 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Do you have any other mods besides the Ganz intake?
Have you tried puttting the stock intake back on just to see how the car reacts?
Can you reproduce the hesitation/bucking every time....or is it more sporadic?
You can try spark plugs....they're cheap & relatively easy to replace.
Legacy777 is offline   Reply With Quote
Old 12-04-2002, 08:39 PM   #3
RSmatt
Member#: 8039
94 v2 STi RA - RHD
Try checking the coilpack for corrosion. It sounds like your car is doing exactly what mine did. I cleaned the bad coil and put some dielectric grease on it. Everything has been fine since then.
RSmatt is offline   Reply With Quote
Old 12-05-2002, 05:56 AM   #4
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
sounds like the same problem this guy had? I had it too, read my advice towards the end of the thread. It's an ignition problem, probably a misfire in cyl # 1 or #3...
http://www.rs25.com/forums/showthrea...&threadid=4821
good luck,
-scott-
scotty305 is offline   Reply With Quote
Need help! Car hesitating and can't figure out why... 97 Pimpreza New England Impreza Club Forum -- NESIC 15 10-02-2009 01:03 PM
WRX hesitation problem, Need help. (NJ) 95 avus blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-15-2005 11:04 PM
Need help on low RPM hesitation/High EGT problem kracka99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 08-28-2005 10:31 PM
Need Help - Terrible hesitation after STi Injector and Walbro Fuel Pump Installation Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 11-30-2002 02:04 PM
Have hesitation need HELP! kaos200 Normally Aspirated Powertrain 13 03-22-2001 11:05 PM
