Old 12-04-2002, 04:19 PM   #1
Arcane
Member#: 10846
Blaq
Default Passport 8500 mounting?
Finally caved and got myself an 8500! My 7yr old 4500 finally died, may it rest in peace. I also got the additional direct power wire cord.
Was wanting to see some pics or get some suggestions as to how you all have mounted your detectors? Any good ninja stealth style ideas or just better than suction cup methods out there?
Also what power lead wire did you tap into for direct power?
Arcane is offline   Reply With Quote
Old 12-04-2002, 04:52 PM   #2
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Lightbulb
i just tap into the cigarette lighter fuse with the positive lead with inline fuse, and find a ground spot for the negative lead. has worked well on every vehicle i have owned.
justin
joostin420 is offline   Reply With Quote
Old 12-04-2002, 05:21 PM   #3
brunetmj
Member#: 8023
2004 2.5 RS
Another good place is the clock wires. Some people also use the wires to the map lites and/or the wires that go to the rear view mirror. If you do a search you can also find a number of "how to"
threads.
brunetmj is offline   Reply With Quote
Old 12-04-2002, 07:10 PM   #4
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
This is how I mounted my detector (A V1), but it still applies for the Passport or any detector. My friend mounted his Passport 8500 with the directions and it seems to work well:
Radar install
Hope this helps.
Paul G.
paultg is offline   Reply With Quote
Old 12-05-2002, 11:25 AM   #5
Arcane
Member#: 10846
Blaq
right on! thanks for the help.
Old 12-06-2002, 12:10 AM   #6
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
Here's pics of mine.. same idea as above.
lenyx is offline   Reply With Quote
Old 12-16-2002, 11:56 AM   #7
Arcane
Member#: 10846
Blaq
well got my 8500 looking just like ^^^ that now. i did notice that i'm going to need to get a rubber spacer and a longer screw probably. the rear sensor on the top is blocked by the light fixture there. i figure by lowering it another 1/4" or so i should be able to clear that.
otherwise i'm pretty happy with how it looks and how hard it is to spot the detector from outside the car. stealth radar detector mounting = priceless.
Old 12-16-2002, 07:48 PM   #8
Zypper
Member#: 5201
'02 WRX Wagon
'11 Versys 650
Pretty nice job there How long did it take you, and Don't you wish it had green backlighting to go with the rest of the car?
Zypper is offline   Reply With Quote
Old 12-17-2002, 01:45 AM   #9
Arcane
Member#: 10846
Blaq
The whole thing took maybe 15 mins max to get everything where i wanted it. Super easy install and well worth the effort.
Yea a green display would be pretty cool
Old 12-18-2002, 10:14 AM   #10
mhbrown
Member#: 12537
'02 WRX Sportwagon
WR Blue Pearl
My install looks a lot like Paul's except:
The V-1 uses standard phone cord and connectors. I fabricated a custom length straight phone cord from the hidden (in the headliner) harness to the V-1. The cord exits the headliner in the plastic cover for the mirror wires and just exits out the side.
I also have the remote display. I ran a fabricated cord from the harness across the headliner and down the A pillar (behind obviously). The cord exits at the bottom of the A pillar and the remote display is tucked into the corner. I have not finalized the location of the remote yet.
mhbrown is offline   Reply With Quote
Mounting the Passport 8500 x50 rich22 Car Audio, Video & Security 20 04-06-2005 08:56 PM
Pictures of Passport 8500 remote mounted in WRX STi dash srf Car Audio, Video & Security 20 10-21-2004 08:31 AM
Escort Passport 8500 mounting/wiring PJBEV5 Electrical & Lighting 15 02-29-2004 02:03 PM
Passport 8500 - mounting/wiring PJBEV5 Interior & Exterior Modification 0 02-25-2004 08:30 PM
Passport 8500 - mounting/wiring PJBEV5 Car Audio, Video & Security 0 02-25-2004 08:29 PM
