Old 12-05-2002, 03:52 AM   #1
twotacosfor99cents
Member#: 14997
Default mmm..PIAA Ion Crystals
Thought I'd put up this picture of these PIAA H3 Ion Crystals that I put on the WRX this evening.. only ~25.00 per bulb (single bulbs) from www.autoseattle.com.
I wanted yellow foglights but not too yellow, so I tried these.. I put one alongside the stock bulb, and it looked brighter.
The beam pattern ->
-Ryan
twotacosfor99cents is offline   Reply With Quote
Old 12-05-2002, 05:23 AM   #2
SubaruFan
Guest
Member#:
Are the ion crystals in the fog lights or the headlights? I'm assuming foglights because you said it's an H3 bulb. Nice how the fogs look white but shine yellow!
-What bulbs are in your headlamps???
--THANKS!
Old 12-05-2002, 11:53 AM   #3
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
Santa is getting me those for christmas.. I've already asked.
But they're cheaper here: http://www.optauto.com/webstore/prod...k=yes&dept=346
lenyx is offline   Reply With Quote
Old 12-05-2002, 01:25 PM   #4
twotacosfor99cents
Member#: 14997
They're in my foglights, yes.. I have Intec 4,350K headlights, they're pretty nice.
-Ryan
Old 12-05-2002, 03:44 PM   #5
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
ok, so wait, is hard to judge from teh pic. since the whole surface of the lamp is bright. But does it really look white at the lamp with a yellow output to the road?
zacek is offline   Reply With Quote
Old 12-05-2002, 04:38 PM   #6
twotacosfor99cents
Member#: 14997
It looks slightly yellow with spots of white.. the color varies depending on angle
-Ryan
Old 12-05-2002, 05:29 PM   #7
Merc
Member#: 15929
07 CTS-V
slick silver
Man I have had those is for about 2 years now. This is my fourth set. They like to blow out due to weather change or moisture. But they are a phat light. At one angle they are yellow, another green, another blue. I can't tell there on now though with my HID conversion. 25 dollars also sounds high for them. Check around when you need another set. Later
Merc is offline   Reply With Quote
Old 12-05-2002, 05:38 PM   #8
Bankheist
Member#: 2237
2000 GC8 STi
2015 Ford Mustang GT
when you drive... all you see is yellow
my friends call them "the suns"
too bad I have a cracked Hella 500 lens
Bankheist is offline   Reply With Quote
Old 12-06-2002, 01:51 AM   #9
JonnySubaru
Member#: 17901
I have them too and they cast a green and eerie blue hue on everything too... hard to get used to at first.
JonnySubaru is offline   Reply With Quote
Old 12-06-2002, 03:32 AM   #10
Javabean2
Member#: 9752
2002 WRX Wagon
Your digital camera is white balancing to the brightest point in the shot - your lights. Can you take some pics with "sunlight" or "outdoors" white balance?
Javabean2 is offline   Reply With Quote
Old 12-06-2002, 01:29 PM   #11
verbal
Member#: 25232
I just upgraded my headlamps to Sylvania Silverstars. Much brighter than stock, nice and cheap too. I've been looking for new fog lights that will work well and not cause problems, ie. higher wattage, etc. I'd like to get some blue-ish tinted foglamps, but I read somewhere that blue reflects a lot and would hinder visibility. I'd rather not have yellow, just don't like the way it looks. BUT these might be an option.
Are the blue reflection problems true? I'd really like blue-ish ones but don't want to hinder my visibility. I have enough problems seeing during night rain conditions, but these silverstars helped a LOT. Thanks for any info.
verbal is offline   Reply With Quote
Old 12-06-2002, 08:03 PM   #12
zacek
Member#: 19467
04 WRX STi
does anybody has pics of PIAA's plasma blue on the FOGS.
Old 12-07-2002, 02:21 AM   #13
FA WRX
Member#: 24229
02 WRX
Angry Stupid Stupid WRX owner!
Ok, first off, read the post subject...
How do I get to the Fog bulbs to change them out? I just replaced my Headlights with PIAA Xtreme white bulbs and I bought the matching PIAA H3s to replace my fogs, but how do I get to the bulb. I admit, I am being lazy here, I didn't look very hard or long on how to do this, but if someone would be willing to help out...
Thanks,
Dave
FA WRX is offline   Reply With Quote
Old 12-07-2002, 02:24 AM   #14
Vostok 7
Member#: 30209
Do you need to
read this in Braille?
Check the manual
inserted smilie, other members will not give you the courtesy.
Vostok
Vostok 7 is offline   Reply With Quote
Old 12-09-2002, 05:37 PM   #15
twotacosfor99cents
Member#: 14997
Just unscrew the three screws on the corners of the foglamp, twist open the grey locking cover (don't bother unplugging the harness), and push down on the wire that holds down the bulb after unplugging the ground wire (covered by a rubber cap), and unplugging the bulb + wire from the plastic thing inside the cap.
When you put it back in, make sure that the notches on the bulb line up with the hole.
It's pretty simple, but one of the screws is a pain in the ass to get back in, the lower inside one. Enjoy.
-Ryan
Old 12-09-2002, 05:52 PM   #16
WAlude
Member#: 17361
20 Urabus
XRW
I bought the hella yellow stars for my 500's.
I don't believe all that piaa crap about 55w looks like 85w.
Mine are 100 watt... not 100w "look"
WAlude is offline   Reply With Quote
Old 12-09-2002, 07:06 PM   #17
mhanch
Member#: 11770
02 WRX
WR Blue Pearl
Yes, blue light reflects back off of particulate (dust/water) in the air much easier than white or yellow light. Thus, blue-tinted lights will dramatically reduce your vision in inclement weather.
BTW: this is why the sky looks blue, because that frequency is refracting off of the atmosphere, and also why sunsets are yellow-red, because those are the only frequencies that make it through that much atmosphere.
mhanch is offline   Reply With Quote
Old 12-09-2002, 10:01 PM   #18
Ki2AiYi
Member#: 30797
2002 Impreza WRX
does anyone know where i can get magenta foglights? i think they look cool, especially on a black car. here are some pics from the legend of speed.
sorry about the low qual of the pics.
Ki2AiYi is offline   Reply With Quote
Old 12-09-2002, 10:14 PM   #19
Qbushido
Member#: 17120
2004 04WRX STi 99 RS
sold and MBP, SQC# 33
forgive my ignorance, but what movie is that and where can I get a copy???
Qbushido is offline   Reply With Quote
Old 12-10-2002, 12:30 AM   #20
Ki2AiYi
Member#: 30797
2002 Impreza WRX
it's called the legend of speed. it's a chinese film staring ekin cheng and cecilia cheung. this is where i got mine from
Old 12-10-2002, 04:09 AM   #21
R.C.Y.K.
Member#: 10389
Ki2AiYi, i am looking for the same thing, but i am looking for Blue tho...
R.C.Y.K. is offline   Reply With Quote
WTB: Piaa Ion Crystals intence Private 'Wanted' Classifieds 10 06-06-2004 02:59 AM
Just installed PIAA Ion Crystal Fog bulbs ImPrEzZzZZA Electrical & Lighting 7 02-16-2004 06:03 PM
PIAA Ion Crystal - H3 Fog Bulbs lumpy Private 'For Sale' Classifieds 5 11-07-2003 08:20 AM
piaa ion crystals for fog lamps - right ones? Butt Dyno Interior & Exterior Modification 6 03-22-2003 11:30 AM
PIAA Ion Crystal Driving Lights Bunky Technical Forum Archive 0 05-17-2000 01:54 PM
