Old 12-05-2002, 06:03 AM   #1
kasio
Member#: 6489
01' GM6
Thumbs up Direct Hits
100+shipping from Challenge1 shut down shop sale
past setting-NGK Iridium plugs&stock wires
Pros-
A little increase of power, smoother idle, and hopefully increase of mpg in the future. Shawn from challenge1 wasn't lying if I still remember there was a debate on the Direct Hits. It's liked only press 3/5 of the gas pedal as I normally does with past NGK plugs and the car goes. It's easly and noticeably felt on freeway driving.
Cons-
If you use the direct hits, then out wires will stick up above the spark plug hole by an inch or more. The wires that come along with the set won't work on RS(the WRX one will work fine.) They are pricey!
Plan to get a set of Magnecor wires for the maximum result
-Jun
kasio is offline   Reply With Quote
Old 12-05-2002, 11:56 PM   #2
shu_chen4
Member Sales Rating: (25)
Member#: 12182
89 S52 E30
did you have any issues with installation? i also bought the kit and absolutely could not get my car run with the system in. i've returned the kit to direct hits and they will hopefully be sending me a new system. i really hope it's worth all of the labor and trouble i've gone through...
shu_chen4 is offline   Reply With Quote
Old 12-06-2002, 03:15 AM   #3
kasio
Member#: 6489
01' GM6
No, I didn't have any problem installing them. Well, actually they were professionally installed; I've just done a small tune-up. I watched how the mechanic do all the works aside. Beside that wires stick out problem, there was no problem installing them at all!
Oh there is this one outer plug to help install each plugs, do you have it in the package?
Good luck!
-Jun
Direct Hits...has anybody tried them? Jademonkey Normally Aspirated Powertrain 8 01-27-2002 07:31 PM
Direct Hits nick dickitt Normally Aspirated Powertrain 7 06-11-2001 11:07 AM
direct hits ignition upgrade ANW Normally Aspirated Powertrain 1 05-05-2001 06:16 PM
Direct Hits plugwires; Any good??? FLUBYUx2 Normally Aspirated Powertrain 6 02-02-2001 06:53 PM
