Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 12-04-2002, 06:29 PM   #1
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Default Stock DOHC 2.5L Rod Length..
Over in the FFI forum, we are working on some stroker kit ideas for the EJ20. (see http://forums.nasioc.com/forums/show...9&goto=newpost)
One piece of information we are missing:
What is the rod length for the stock 2.5L Rods on the SOHC and DOHC motors?
According to www.jepistons.com, the DOHC(97-98) is 5.135" and the SOHC (99-) is 5.165".
However http://www.pauter.com/subaru.htm shows the DOHC and SOHC having 5.180" rods.
Anyone know which is correct, or have a stock 2.5 rod they could measure?
Thanks!!
Jeff Sponaugle
[email protected]
sponaugle is offline   Reply With Quote
Old 12-05-2002, 12:47 PM   #2
outback2.5HO
Member#: 15135
95 GF WRX
MRT makes complete stroker kits for the EJ20s that bring them to 2.2. They are pricey (+-$3k), but proven.
Are you going to start driving in PGT, or just codriving? It seems as though you have been busy with your WRX, maybe prepping for next season?... Did you have to modify the tranny tunnel to get that 6 speed in there? Did you get the center diff adjustment with that too? At any rate, nice set up.
outback2.5HO is offline   Reply With Quote
Old 12-05-2002, 01:37 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I have a stock rod from my MY00 SOHC engine that went kaplowie. Send me a PM as a reminder, and I'll check the length when I get home later tonight.
Brian
North Ursalia is offline   Reply With Quote
Old 12-05-2002, 01:46 PM   #4
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
I'll still co-drive with Mika, it was a blast last year. I'll keep my car setup for track racing, which is what I really dig... This winter will be some good prep time, and I should be able to get this STI stroker setup working well.
The 6 speed dropped right in.. no tunnel mods. It doesn't have the adjustable center diff though. The front LSD works great though.. pulling out of corners is awesome now.
I still have the regular viscous rear diff, but will be putting in the STI R180 LSD rear diff this winter with the new STI rear hubs and axels I just got..
Jeff
Old 12-05-2002, 06:36 PM   #5
outback2.5HO
Member#: 15135
95 GF WRX
That's good news. I heard that the 6 speed was bigger and required some trans tunnel "customizing". What gears come in that tranny? That front LSD sounds like a good improvement. Planning an EG33 swap into my Outback, and the 4:11s with a 5 speed are a bit too short for the 6cyl (even the 2.5) on the highway. But a 4:11 with a 6 speed...
That would be sweet. Are they still +-$3500? Might just opt for an early turbo Legacy tranny w/3:90s, just weighing my options.
Glad to hear that you'll still be in the Rally scene. You guys were turning some good times at Oregon Trail. Hope to see you at Doo Wops.
Good luck with your stroker kit and all of the other STI goodies.
BTW, can you get an STI engine complete? I have a friend in dire need of the best EJ20 he can get his hands on. He has a turbo the size of a cabbage that wasted his lower end during the Taste of Subaru...You might have seen it go up in smoke. He's planning on a stroker for his also, if he can't get an STI.
DOHC 2.5L or 2.2L needed in Central Florida! DOHC_Holiday South East Region Forum 2 09-24-2008 09:19 PM
DOHC 2.5L or a 2.2L, Florida DOHC_Holiday Private 'Wanted' Classifieds 1 09-23-2008 08:07 PM
Is anyone actually running SOHC gaskets on a DOHC 2.5L? Patrick Olsen Normally Aspirated Powertrain 2 04-09-2002 03:29 PM
swapping out DOHC 2.5L engine for SOHC 2.5L engine 2.5GT Normally Aspirated Powertrain 2 11-14-2001 03:58 PM
Anyone know where I could find a DOHC 2.5L dyno graph? Patrick Olsen Normally Aspirated Powertrain 12 08-27-2001 06:00 PM
