Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 12-05-2002, 01:24 PM   #1
steveg71002
Member#: 29057
2001 impreza 2.5rs
black
Default hp gains
i have an 01 2.5rs. i have an aem short ram intake and apexi n1 catback exhaust. i want to get as much horsepower as possible and would like to possibly get in the 13's. is this possible without a turbo. and if so, what could i do to it. i was thinking headers, cams, pulleys, injectors. i need help. i don't know much about this. thank you.
steveg71002 is offline   Reply With Quote
Old 12-05-2002, 02:12 PM   #2
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
try the NA forum
For big NA power, you'd need cams, valvetrain, maybe higher compression pistons, etc... + your basic boltons, clutch, flywheel, pulleys...
question is, how much money do you wanna spend?
cRayZee is offline   Reply With Quote
Old 12-05-2002, 11:52 PM   #3
kturner
Member#: 8225
There is a lot of material on this around here. Do you know about the search function? From my many hours of post reading, I conclude it will cost a fortune (many thousands) to run 13's NA. Then your tranny will break from drag racing. Nitrous is the best bang for the buck at around $500. Maybe bang is the wrong word. I use a ZEX kit.
kturner is offline   Reply With Quote
anyone know if you can swap heads from ej22 to ej18 hp gains torque gains high cmprsn turbocolin Normally Aspirated Powertrain 5 12-06-2004 08:42 PM
K&N panel filter HP gain? malelee21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-02-2001 02:51 PM
What HP gains could i get from these mods? Shrubba Normally Aspirated Powertrain 6 04-07-2001 11:00 AM
hp gains? guesstimations smacksube Normally Aspirated Powertrain 6 03-10-2001 12:02 AM
cheap HP gain KITTbri Newbies & FAQs 4 10-24-2000 04:58 AM
