Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 12-05-2002, 04:40 PM   #1
scoobydude
Member#: 609
96 Impreza
Default 1.8l upgrade to 2.5l ???
Does the ECU and/or engine wiring harness have to be replaced as well? Has anyone done this?
scoobydude is offline   Reply With Quote
Old 12-05-2002, 06:09 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The EJ18 is OBD I, so you would need to swap the ECU and Wiring harnass for the EJ25 to run properly. At least thats what I would do... Some folks enjoy jury-rigging their wiring, but a harnass + ECU is not THAT expensive to not do it.
Old 12-06-2002, 01:03 PM   #3
redwagon
Member#: 2181
2008 SpecB
Default MY00 1.8LS
I have a 1.8LS with MAP, is this also OBD I? Surely it's ODB II.
Would a SOHC 2.5 MAP motor and ECU plugn'play?
redwagon is offline   Reply With Quote
Old 12-06-2002, 01:28 PM   #4
RaceCarRiot
Member#: 6542
1997 Ver IV
Default Re: MY00 1.8LS
subaru went to OBDII starting in 96, so you should be OK in that regard, but i would bet it's safe to say that the ECU and wiring are going to be different. you'd probably have an easier time than someone with an older GC8 though.
RaceCarRiot is offline   Reply With Quote
Old 12-06-2002, 01:56 PM   #5
legacyej22
Member#: 23385
My car is a 95 and I'm pretty sure it's OBD II, at least thats what it say on the underside of my hood....
Josh
legacyej22 is offline   Reply With Quote
Old 12-06-2002, 02:03 PM   #6
awdwagon
Member#: 6585
1997 acura integra
champion white
typically OBD2 started in 1996
Kostamojen- when you said about swapping the wireing harness with the RS's do you know if you can just swap theengine harness it self or do you have to swap everything on the car? for example on the honda/acura motors you bacically unplug 6 main plugs and you can pull the motor and tranny out together, i didnt know if subaru was the same way(im to lazy to go out and open my hood ). and if its not the same way how much of the wireing harness do you have to change?
awdwagon is offline   Reply With Quote
Old 12-12-2002, 10:23 PM   #7
scoobydude
Member#: 609
96 Impreza
It's ODB II as the ODB II scanner that I borrowed worked fine. I guess I'm just gonna have to take the plung and give it a try. Now I just need to find a motor for a decent price.
1.8L to 2.5L worth it? Not-EWRX Subaru Conversions 6 05-28-2008 04:26 PM
96 1.8L Brighton to 2.5L? HELP. soccerdommer Subaru Conversions 2 04-24-2008 10:21 PM
1.8L to 2.5L swap meansubi Transmission (AT/MT) & Driveline 2 08-10-2007 02:55 AM
1993 Impreza L, 1.8L Swap to 2.5L. What Clutch fork? cybin Subaru Conversions 3 07-13-2006 04:45 AM
Engine Swap 1.8L brighton to 2.5rs? AsherK Normally Aspirated with bolt-on Forced Induction Powertrain 3 02-11-2002 02:52 PM
