Old 12-05-2002, 08:51 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Wild! 4wd CVT Pleo, no center diff or propshaft?!
So the front wheels are powered by the CVT while the rear wheels have a 42 volt electric engine!
The throttle position is monitored and the correct amount of torque is applied to the rear as needed.
I have to say the PLEO is one of the coolest cars I have seen, can you imagine a forced induction intercooled cvt MICRO car with almost zero drivetrain loss? This thing must be very fast and handle like mad.
Taken from http://www.performancesubaru.com/newspress.htm
Full text:
Back to the Future for Subaru's Concept Car - Retro styling cues combined with all-wheel drive via an ingenious electric motor are highlights of Subaru's HM-01 concept car at the Frankfurt Motor Show. Designed to evoke memories of the 1958 Subaru 360 - the company's first car the HM-01 is on display on stand C06, Hall 8. Despite featuring trafficator indicator arms protruding from the A-posts and 50s style side panel crease lines, the HM-01 also succeeds in looking practical and contemporary, with a wheel-at-each-corner 'planted' look. The HM-01 uses the front wheel drive platform from the Japanese home market Pleo microcar. It's 658cc straight-four petrol engine drives the front wheels via Subaru's i-CVT (Continuously Variable Transmission). The rear wheels are driven by a 42volt electrical motor system. Cleverly, the difference between front and rear wheel speeds is synchronised electrically.
Wired Up for Sound Grip - Instead of a propeller shaft running to the rear to power the rear wheels, the HM-01 has wires that pass current to a rear mounted motor that looks after the rear drive. A central processing unit monitors driving conditions and the throttle position and distributes power in the most efficient and environmentally friendly way possible. When the car is cruising on the overrun, the momentum of the rear wheels is converted into electric power by the alternator in the rear drive unit which also recharges the batteries. The electrical components consist of a 42 volt system utilising a readily available, easily recyclable 36 volt sealed lead acid battery. This is used in conjunction with a regular 12 volt unit, a high-power 3 kW alternator and a DC-DC converter that takes the power down to 14 volts for the rest of the cars electrical system
Old 12-05-2002, 09:15 PM   #2
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
That is a neat little car, and an interesting concept. I wonder if it will ever make production? I wouldn't mind owning a 360 either, just to have a piece of Scooby history, but they are pretty hard to find (even though I know SubieGal has two ).
-Wes
RebelINS is offline   Reply With Quote
Old 12-06-2002, 12:07 AM   #3
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Well
Why not turbocharge an AWD Subaru Justy with the ECVT tranny?
That's one of the things I'd like to do.
Kevin Thomas is offline   Reply With Quote
Old 12-06-2002, 02:32 PM   #4
steve_d
Member#: 315
The eCVT will never hold it...my bud blew two of them in 1 season of autocrossing...
sjd
who's picking up his 360 this week or next...
steve_d is offline   Reply With Quote
Old 12-06-2002, 07:33 PM   #5
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Huh, cool...
That's very similar to the system used in Cornell University's current Hybrid Electric Vehicle:
http://www.hev.cornell.edu/
A turbocharged Miata engine run off natural gas powers the rear wheels and an electric motor powers the front. The batteries can charge by using the front motor as an alternator.
vrg3 is offline   Reply With Quote
Old 12-08-2002, 08:28 AM   #6
aspera
Member#: 7879
That's "through the road" four wheel drive. Besides giving the advantage of all wheel drive, it lets a front wheel drive car become a hybrid-electric vehicle without having to cram all of the electric stuff under the hood. The car loses cargo space and increases in weight, complexity, and cost.
You also have to wonder EXACTLY how the four wheel drive system works. Is it an automatic full time system? What is the torque split when different wheels lose grip? If both front wheels spin at WOT, do the rear wheels maintain maximum torque or try to match the torque being applied to the road by the front wheels (nearly nothing)?
aspera is offline   Reply With Quote
Old 12-08-2002, 08:31 AM   #7
aspera
Member#: 7879
"distributes power in the most efficient and environmentally friendly way possible"
This sounds like my low RPM torque on my WRX....environmentally conservative boost.
what wrong center diff or rear diff my name Transmission (AT/MT) & Driveline 0 12-08-2006 10:16 PM
Stock 5 Mt Center Diff Or 20kg Unit WRXINTX Private 'Wanted' Classifieds 0 03-10-2006 02:20 PM
01rs center diff or tranny fosingwo Private 'Wanted' Classifieds 3 01-23-2006 12:46 PM
WTB: center diff/ or 5sp tranny gren737 New England Impreza Club Forum -- NESIC 13 06-02-2005 02:23 PM
center diff or rear diff causing rear wheel spinnage!! askep18 Transmission (AT/MT) & Driveline 0 08-08-2004 05:29 AM
