Old 12-05-2002, 09:16 PM   #1
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
Default Question about actually USING n20
I've been doing a lot of searches, but I have not come across one addressing exactly how to use it. More specifically using a dry zex kit. In the threads I previously read, it said that once you have the switch flipped to on, its sprays automatically at WOT. Is this correct? If it is, how exactly would you not use it in 1st and 2nd gear(which most of you advise against due to hitting the rev limiter). The only thing I can think of, is to flip the switch after 2nd?? But trying to shift, drive, and hit a switch all at the same time seems pretty difficult. Is there something obvious that I'm just missing?
AustinSTi is offline   Reply With Quote
Old 12-05-2002, 10:31 PM   #2
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Yes, this system works off of the TPS and is active at only wide open throttle.
In response to your question, there is no reason why you can't use this in first and second gear...as long as you are a decent driver and can let up to shift before you hit the fuel cutoff. As a matter of fact, using it in only third, you will not notice the nitrous nearly as much, as the main kick is in first and second and most of third. You don't feel it hardly at all in fourth and fifth and if you have a stock clutch it will probably slip in fourth and fifth gear pretty badly.
Garret
Ghomer1 is offline   Reply With Quote
Old 12-05-2002, 11:38 PM   #3
kturner
Member#: 8225
I have this kit too. It will rev very quickly in first and even second. You have to be careful if spraying in those gears. Hitting the rev limiter would be a bad thing. It isn't much of a problem for me though since I blast it mostly in 3rd and even 4th for highway passing. As long as you stay off absolute WOT, it won't go off - it takes that last little push.
kturner is offline   Reply With Quote
Old 12-06-2002, 12:12 AM   #4
Mauricio
Member#: 2823
couldn't you just put something behind your pedal to keep you from going WOT?
Mauricio is offline   Reply With Quote
Old 12-06-2002, 12:24 AM   #5
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Its not that hard to control the nitrous. It does take that extra push to arm the nitrous. Meaning you have to have it all the way to the floor you move it up the slightest bit and it cuts off. Man I guess I have been missing out I only spray once on 3rd gear and then sometimes I spray in 4th to but thats it. Boy do I need a bottle heater too...
AndyM is offline   Reply With Quote
Old 12-06-2002, 12:29 AM   #6
AndyM
Member#: 3219
WR Blue Pearl
...what I do is I flip the switch on jet to about 30 mph then hit the nitrous until I get to 5,800 RPM (somewhere around there) then I let off the gas a little shift into 4th then hit the nitrous again. After that when I shift into 5th I turn off the switch.
How is everybody's Nitrous system doing?
Any good runs, got any tips that you have learned?
I love when people post, it gives me a chance to talk to other Subaru owners about nitrous
Old 12-06-2002, 12:47 AM   #7
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
I'm also interested to see how 4EAT Subaru owners use their N20 I've never actually seen N20 used with my own eyes, I think their experience would really help me decide whether I should get one or not.
Hopefully Kevin Thomas will come around and enlighten me
DrBoy01 is offline   Reply With Quote
Old 12-06-2002, 02:47 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
what you can do to combat hitting the limter is installing an MSD window Switch unit which will automatically turn the nitrous controls on @ 3k rpm and turn off at your selected speed(i rec shutting down at 6k).
jeremy
Old 12-06-2002, 12:30 PM   #9
AndyM
Member#: 3219
WR Blue Pearl
Exactly what Jeremy said for about $100.00 from www.summitracing.com you can get the MSD window switch and (2) sets of RPM pills. I have this and it works great. You just need to go out and buy a 30-amp relay my switch wouldn’t work without it. It made my RPMs go up from about 750 to 1,500 RPM got the relay and now it works great. If you do get the switch do not buy MSD its a rip off. I got my 30-amp relay from radio shack for $2.30 beats havening to pay something like 30 for a simple relay.
Old 12-06-2002, 12:51 PM   #10
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
why do you not turn it on till 3000rpm
it seems like you would have the most to gain in the lower rpms' where the car is lacking in power to add the nitrous...
nomadtw is offline   Reply With Quote
Old 12-06-2002, 08:33 PM   #11
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
Just curious but for those of you with nitrous what other mods do you have ? and are there any mods you should stay away from ?
Mr. Rogers is offline   Reply With Quote
Old 12-06-2002, 10:55 PM   #12
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
i spray in 2nd all the time, and sometimes towards the end of first. if you mount your switch in a good spot, its really not hard to reach and flip it in between shifts. like i said i can arm it in the middle of 1st and have my hand back on the shift knob ready to go by the end.
hey, i have an 02 ts too. im running a zex dry kit with a jet in between the 55 and 65 shot jets they give you, so well just say a 60 shot. only other mods are weapon r intake and universal muffler. ive run dead even with firebird formulas from a 20mph rolling start, damn near beat that wrx with an apex exhaust and txs boost controller, and beat a viper through the 1/8th mile at a local track by half a second (granted, that guy probably just couldnt drive, and he SMOKED me after the 1/8th ) my car always still runs rich and the plugs never show any signs of detonation. ive also never recieved a CEL due to it.
jasona is offline   Reply With Quote
Old 12-06-2002, 11:33 PM   #13
kturner
Member#: 8225
I think the on-spray rpm point is somewhat gear dependent. You can probably start spraying in lower gears at lower rpms. The main thing I try to do is be into a free revving (one v, two?) range. Lugging the engine is bad anytime, with all that extra fuel and oxidizer, lugging is even worse on nitrous. When most kits spray, they shoot one rate of nitrous in and dump in what is supposed to be a corresponding amount of fuel. So if you're at 2000 rpm making, I don't know maybe 100 hp, and you shoot in a 55 shot you just dumped in 50% more mix. At peak hp 165 the relative increase is 30%. It's a stress thing. Or I have no idea what I'm talking about.
Old 12-07-2002, 03:13 AM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
because spraying nitrous under 3k RPM is a good way to load up a cylinder and bend a rod, the problem is your airflow is not high enough to accurately distribute the nitrous. On a 4 fogger system this isn't too much of an issues(but you still shouldn't spray under 3k RPM) when the bottom end is spinning and making good amounts of power.
jeremy
Old 12-07-2002, 08:15 AM   #15
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
ABout time I heard of a TS on nitrous thanks man.. I was thinking of putting on at least a cat-back exhaust first and then going the nitrous route with a progressive controller. Its an easy mod and when I have lil man in the car I don't need to worry about going to fast cause my foot is heavy LOL.
Old 12-07-2002, 02:40 PM   #16
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
when i was refering to "difficult", i was talking about taking it to a 1/4 mile track and seeing what the car could do. But after reading your responses, it seems that the kit is very sensitive in when it turns on and off? Is that a correct assumption, that with the slightest let off of the accelerator pedal, the n20 stops spraying (aka when i shift), and then comes on quickly when i stomp the pedal again? Or is there some sort of a delay/lag?
Old 12-07-2002, 02:47 PM   #17
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
that's what they RPM activated window switch is for, you have a WOT switch that actually controls the N20 flow and the window switch would turn the system off when the car hits 6k rpm so that way by the time you **** the nitrous has been run out of the intake and when you shift you are right back into it.
jeremy
Old 12-07-2002, 04:36 PM   #18
kturner
Member#: 8225
You are basically correct. In most systems, the nitrous starts flowing promptly at whatever point you have set the micro switch or throttle position sensor to interpret as WOT. When you let off throttle to shift. it also stops sparying instantly but takes probably a micro second to flush through the manifold. Then when you hit WOT again, it sprays again. Apparently, you can adjust how fast/hard your system hits by where you locate the spray nozzle. Right at the throttle body will be a bit quicker than 18 inches from the stock air box. Some systems do have delays and variable spray rates that can be programmed. These are used for drag launches to avoid too much wheelspin off the line.
Old 12-07-2002, 06:40 PM   #19
jasona
Member#: 11786
2014 OB 2.5i 6MT
when you program the computer, you have to push the gas pedal in (or if youre doing it by yourself, push the little throttle lever under the hood with your fingers) to the point you want the kit to activate. it you push it all the way, it will only spray when you push the gas pedal all the way. if you only push it like half, then it will start spraying when you hit half throttle.
Old 12-07-2002, 06:45 PM   #20
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
WARNING: DO NOT USE THE THROTTLE LEVER UNDER THE HOOD
why you ask?? because your gas pedal travel will most likley NEVER pull the plate full WOT and you need to have a WOT threshold...infact you can end up with 2 different WOT percentages just using the pedal in the car, depending on how much pressure you are exerting against the pedal with your foot.
jeremy
Old 12-08-2002, 04:54 AM   #21
jasona
Member#: 11786
2014 OB 2.5i 6MT
i always use that thing what could go wrong?
Old 12-08-2002, 05:25 AM   #22
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
that's for people setting their WOT threshold on the ZEX systems....it's not an accurate way of setting it up as you will never see 100% WOT like you would by turning that cam.
jeremy
Old 12-08-2002, 11:44 AM   #23
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
Since we are on the topic.. ANybody have any comments about the uber n20 system , LOL, Venom VCN-2000 ?
Old 12-08-2002, 10:44 PM   #24
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
I'm going to re-ask my question:
Can anyone who has N20 and a 4EAT explain how they use it in their rides (ie. what RPM do you activate the system, how you shift, etc.)?
Old 12-09-2002, 01:54 AM   #25
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
read what was posted before, turn it on at 3k and let the ECU shift cause if you hit the limiter on dry N20 shot you can kiss your pistons goodbye
Question about daily use of AP V2 down_for_the_scooby AccessPort 7 08-18-2009 07:23 AM
Question about swapping used pads onto new rotors? sd 05 sti Brakes, Steering & Suspension 3 11-07-2007 04:42 PM
Serious question about drug use Sharkbait Off-Topic 67 03-21-2007 05:30 AM
Questions about a used STi ruski General Community 16 10-15-2005 01:20 AM
questions about buying used car and taxes setiawani Off-Topic 9 08-04-2003 07:34 PM
