Old 12-06-2002, 12:39 AM   #1
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
Default Which fuel preasure gauge setup
Again I am wondering what others are doing for a fuel preasure gauge? I would also like to know where you get all the fittings to install them thanks!
cpu77 is offline   Reply With Quote
Old 12-06-2002, 12:59 AM   #2
kturner
Member#: 8225
I have the Autometer electric. I got some brass fittings from a good hardware store. It was a brass block pipe thread tapped three ways. I put in two hose barbs and screwed the sender into the third. I tapped this into the fuel line just after the fuel filter. It's a little bulky but is working good. I think Jeg's may have some more sophisticated versions. There's also this electrical box converter that goes with it that I mounted against the left side of the car down by my foot.
kturner is offline   Reply With Quote
Old 12-06-2002, 11:06 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I would definetly go with the autometer Electric.
Not sure if they even make them for Fuel Injected engines but don't use a mechanical gauge. Their accuracy is horrible.
Eric
Eric SS is offline   Reply With Quote
Old 12-06-2002, 12:33 PM   #4
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
I use an Autometer Electric gauge too. Not only are Mechanical gauges not especially accurate for this, but they come with warnings all over the packaging telling you not to mount them in the cabin, because, if they start leaking, well, you get the picture.
Anyway a fuel pressure gauge is not the place to skimp -- you want to have confidence in anything electrical that touches your fuel system. Or at least I do...
Anyway though, you should be able to find all the fittings you need at home depot or an auto parts store. I did the same thing as mentioned above.
Darshu is offline   Reply With Quote
Old 12-06-2002, 10:45 PM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
I just bought a greddy tonight.
I'll install it tomorrow and see how I like it.
Brad
STiTuner is offline   Reply With Quote
Old 12-07-2002, 12:58 AM   #6
wei
Member#: 3719
here is mine
wei is offline   Reply With Quote
FS Defi Gauge Setup, Grimspeed BCS, Walbro Fuel Pump whontime Engine/Power/Exhaust 26 03-18-2010 10:55 PM
can I use a fuel pressure gauge for my water injection setup? garie Water/Methanol Injection, Nitrous & Intercooler Cooling 1 11-18-2005 12:51 PM
fuel preasure regulater dohced Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-10-2005 07:43 PM
Does anyone make a Aftermarket fuel preasure regulator for a WRX SupraTT&WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-25-2004 10:12 PM
Fuel preasure regulator for SC motor Scooby43055 Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-09-2001 03:57 PM
