Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 12-06-2002, 02:34 PM   #1
Sublime5260
Member#: 30488
2006 Acura TL
Gray
Default To all of you out there that are having trouble getting into reverse.
As the transmission gets warmer, it gets harder and harder to shift into the reverse and the rest of the gears keep getting notchier. If you are having trouble getting into reverse, try going in to 5th first and then try shifting into reverse. If you still cant get in, go to 4th, 5th, and then shift into reverse. This way, the synchros should align and it should work.
Sublime5260 is offline   Reply With Quote
Old 12-06-2002, 03:19 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
everyone SHOULD have trouble getting into reverse...
it's not synchronized.....
double clutch.. no worries...
jamie
www.subiegalracing.com
Get ya Subie Gal Rally Posters!!
www.allsubaru.com
Old 12-08-2002, 12:51 AM   #3
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Default Re: To all of you out there that are having trouble getting into reverse.
It's the other way around for me: stiff when cold; OK when warm.
Edit: unless you wrote the opposite of what you meant, you may have a tranny problem.
Mike Wevrick is offline   Reply With Quote
Old 12-14-2002, 06:59 PM   #4
Onlnagent
Member#: 11580
2015 STI
CWP
Thank god! I was having trouble getting the car into reverse also when the car was cold. I would Try to put it in and if it would not go in smooth I'd blip the gas and when the RPM's dropped to idling speed it would usually go in. Now that I know that there are no syncros in reverse that explains it all.
Onlnagent is offline   Reply With Quote
Old 12-14-2002, 07:19 PM   #5
Sublime5260
Member#: 30488
2006 Acura TL
Gray
i didnt mean the opposite of what i wrote, when the transmission is cold, its really easy for me to get into reverse but the rest of the gears are a little stiff. When I drive a lot in one day and when the transmission gets really hot, reverse is very hard to engage and the rest of the gears aren't as slick. Even tho reverse isn't synchronized, going into fifth before engaging reverse helps a lot. I really don't think i have a transmission problem, what do you guys say?
Old 12-15-2002, 02:38 AM   #6
teiva-boy
Member#: 22825
Well putting redline oil in my car really made things worse for me on really hot days like in the 85's+ degrees.
I'm now going to try Torco synthetic or regular, depending on my spending mood and what kind of deal my local speed shop cuts me.
teiva-boy is offline   Reply With Quote
Question to all of Alaskans out there PATR1KI Alaskan Impreza Club Forum -- AKIC 31 11-12-2008 08:19 PM
to all of you who use racks... i have a question wrxproject Interior & Exterior Modification 3 05-02-2006 06:16 PM
HELP; trouble getting into Reverse and 5th gear amye66 Transmission (AT/MT) & Driveline 4 01-20-2006 02:13 PM
Are there that many guys out there that are this clueless? I am b Off-Topic 14 03-30-2004 04:22 PM
Trouble getting into reverse tomrichardson Normally Aspirated Powertrain 15 11-02-2000 10:49 AM
