Vancouver Impreza Club
Old 12-06-2002, 03:53 PM   #1
JP
Member#: 443
1999 Impreza TS
Default break question~
Will WRX front caliper fits MY99 TS?? How about OLD age RS? fit TS as well? Thank you very much!
JP is offline   Reply With Quote
Old 12-06-2002, 04:36 PM   #2
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
WRX and old RS have the same caliper (with a different mounting bracket since the WRX uses a larger disc.) I'm pretty sure RS/WRX front brakes can be put on a TS. If you run WRX brakes, you need so use 16" or larger wheels.
AllWheelDrift is offline   Reply With Quote
Old 12-06-2002, 05:13 PM   #3
youthanasia
Member#: 1883
2013 R60S All4
What he said. You can't use your stock 15"s anymore.
Personally, as a fellow TS owner, I'll just upgrade my fronts to RS calipers and get some good Rotors from EBC, Brembo OEM replacement rotors or DBA rotors with some good pads, and I get to keep my 15" stockers and steelies for winter use. When you have enough spare change in the future, go do the rear disk mod with 2000+ legacy rear disks and a brake proportioning valve.
Cheers;
Peter
youthanasia is offline   Reply With Quote
Old 12-06-2002, 06:15 PM   #4
JP
Member#: 443
1999 Impreza TS
How about Legacy front caliper?? fit also?
I still wanna keep my 15" wheels! I think that i should go with RS or Legacy calipers!
Old 12-06-2002, 07:33 PM   #5
4wheelflyer
Member#: 18247
90 R32 Skyline
GTS-T Type M
I am just about to do that mod, just picked up the braided stainless steal brake lines. Im going to put vented turbo legacy rotors and calipers on front and rear. subaru says this set up will out perform RS and WRX brakes, lets hope so. bye bye spongy brakes
4wheelflyer is offline   Reply With Quote
Old 12-06-2002, 07:56 PM   #6
Koyo
Member#: 19332
Has anyone done a H6 rear rotor swap yet??
Koyo is offline   Reply With Quote
Old 12-06-2002, 08:02 PM   #7
youthanasia
Member#: 1883
2013 R60S All4
Go with RS calipers. MY2001 or earlier. IT's the same caliper that the WRX uses and you get a better selection of pads. As for the Legacy front calipers, yes it would fit as well, I just don't know if they are the same or not.
Old 12-06-2002, 11:04 PM   #8
Ooter
Member#: 20395
87 VW "TSD" Golf
Past 2002 & 2003 BRP TS
Hey guys, for changing the rear drums to disc, is there a special bracket required to mount the caliper or is it a straight bolt on?
Ooter is offline   Reply With Quote
Old 12-06-2002, 11:08 PM   #9
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
I believe you need the knuckles and hubs from a car with discs. It's not that easy in terms of parts...
Old 12-06-2002, 11:38 PM   #10
Benjamin Tang
Member#: 4496
2009 Forester
red
there is a section in this board that deals specifically with this stuff. i recall awhile back someone asking the exact same question, and there was a detailed step by step response from someone else.
maybe http://www.scoobymods.com might have something to help u?
Benjamin Tang is offline   Reply With Quote
Old 12-07-2002, 02:20 AM   #11
Ooter
Member#: 20395
87 VW "TSD" Golf
Thanks Bruno, I found a great link regarding this conversion. Probably a year or two until the rear pads where out, then I'll consider it.
Sounds like fun!
http://wac.addr.com/auto/obs/disc/disc.html
Old 12-07-2002, 04:43 AM   #12
JP
Member#: 443
1999 Impreza TS
anyone know will legacy front caliper fits 99' TS ???? thx thx
Old 12-07-2002, 05:20 AM   #13
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Probably, but it might depend which Legacy. I know tora's 2002 Legacy Brighton has 1pot fronts, which are probably the same as TS brakes anyhow.
I *think* the Legacy GT/Outback use the same 2pot fronts as the new RS/TS do, which are a bit different from the old RS and WRX. I imagine those would still bolt up but I'm just guessing. They also suffer from poor pad selection. As youthanasia said, you really are best of with GC8 RS calipers.
Old 12-07-2002, 02:31 PM   #14
JP
Member#: 443
1999 Impreza TS
thx for all the help!
I better stick with old RS caliper! hope someone will sell caliper later on~ haha
Sorry guys, newbe Question~ 07 STI BOV?? andykou Newbies & FAQs 12 03-03-2008 04:04 PM
exhaust question~ gelgel Newbies & FAQs 6 08-09-2004 06:52 AM
springs question~ gelgel Vancouver Impreza Club Forum -- VIC 21 05-25-2004 01:47 PM
just a quick question~ gelgel Vancouver Impreza Club Forum -- VIC 8 05-15-2004 01:28 AM
Warranty Question~ Help! GoGoGo Vancouver Impreza Club Forum -- VIC 2 06-05-2002 04:39 AM
