Old 12-06-2002, 07:21 PM   #1
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Question Car idles rough and drives rough as well
All of a sudden the car started to idle and ride rough. Yes, all of a sudden. This happens at all rpm's and loads.
I have lost a good 25% power and about 30% fuel economy. It's not bad fuel as I have refilled the tank a few times cause the gas milage is so bad. I tried new plugs and that doesn't help. I've tried my coil pack and wires on another car and they work fine. I've tested the compression and all of the cylinders are in between 175 and 190. I've plugged in the stock ecu and that didn't fix the problem. I've also hooked up a node tester to the injector harnesses to make sure that they are not receiving a constant signal from the computer keeping them open.
The only thing I can think of is my timing is off or an injector is getting stuck open. I'm not burning any oil and I'm not hearing any strange noises.
Any ideas? Timing off, broken piston?
4 lbs of boost, 93 octane with no knocking or det. reported on the Link, btw
wcbjr is offline   Reply With Quote
Old 12-06-2002, 07:23 PM   #2
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
What type of fuel pressure regulation are you using?
Is the Link showing that you are also running very rich?
Are all your voltages within spec from your sensors?
other than your current problem... how's the link? PM me.
ImprezaRSX is offline   Reply With Quote
Old 12-06-2002, 07:25 PM   #3
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
What do your plugs look like? Did you check the wires from the ECU to the ignitor? Plug wires?
Darshu is offline   Reply With Quote
Old 12-06-2002, 07:31 PM   #4
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
ImprezaRSX - FPR is an SX Performance that came from the Vishnu rail kit. The Link says I am running real rich, so rich the O2 reading doesn't work very well anymore.
Darshu - All the plugs are fine, both sets I tried.
I forgot to add that cylinder 1, where the EGT probe is, now measures 200 degrees less than normal, like 1200 instead of 1400.
Old 12-06-2002, 07:40 PM   #5
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
EGT's are lower because you are rich.
Rich conditions like this are usually two things:
High fuel pressure- check it, maybe something failed
Bad O2 Sensor.
Old 12-06-2002, 08:10 PM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I know I am rich, hence the lowered gas mileage and erratic O2 readings. Fuel pressure is solid and does not taper off when the car is shut off, so I don't think an injector is getting stuck open. If it was, then the fuel would be dumped into the cylinder and the fuel pressure would go down. Even if the O2 malfunctioned, I have lambda tuning turned off on the Link. I basically don't even use the O2 sensors cause they suck anyways.
Old 12-06-2002, 08:11 PM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Ok, let me ask this. What does happen when a timing belt is off?
Old 12-06-2002, 08:21 PM   #8
Stranger
Member#: 728
2000 2.5RS-T Stage2
I might have a simular problem.
BTW: what happens when the O2 sensors go bad?
Stranger is offline   Reply With Quote
Old 12-06-2002, 08:27 PM   #9
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
So what you are saying is that you are open loop all the time like a carburetor.
That doesn't sound very efficient to me, but if it works.
Are you running a RRFPR?
IF so what are you running for pressure at idle?
A timing belt would hurt your idle quality but I can't see how it would make you rich... unless it was REALLY far off. Then I don't think it would even start.
Have you tried running with Lamda tuning on?
You say you checked spark.
You say the injectors aren't stuck open and fuel pressure is fine.
Last element is air. Did you suck a sock into your intake?
It really sounds like too much darn fuel. You said you ran BOTH the stock ECU and the Link, right? So it must be something that isn't affected by the ECU. Like a broken MAP sensor, or high fuel pressure.
Old 12-06-2002, 08:29 PM   #10
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
This:
Text book O2 sensor.
Depends on the failure. Sometimes they run like crap on the low and mid, but at WOT they run alright because you hit open loop up top.
Old 12-06-2002, 08:38 PM   #11
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
ImprezaRSX - I think you're missing that the Link does not use O2 sensors to adjust fuel. It actually doesn't use them at all when lambda tuning isn't being used. Also, it isn't a bad MAP sensor unless both the stock MAP sensor and the Link MAP sensor went bad at the same time. Fuel pressure has been constant 40psi at all times, rising at a rate of 1:1.
Old 12-06-2002, 08:43 PM   #12
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
No I didn't miss that.
I was just telling the other dude that this SOUNDS like the classic O2. However, your situation must be different.
I did forget that the Link has it's own map sensor, however. Did it come unplugged? <--- that would cause you to be rich until you started to boost, then it could go lean.
Sorry that I'm not more help.
Do you have an A/F gauge? If so, what's it hooked up to?
Old 12-06-2002, 09:06 PM   #13
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
well this happened to me right after my install with my EJ22T block, fuel pump, larger injectors and new turbo... i always thought it was the larger injectors... (RC 440) but on my path of finding this problem... nothing... (i get 150 miles per tank... thats crazy...)
i changed the O2 twice... nope
changed my stock injectors back in ... nope
spark plugs tried every kind even iridium ... nope
igition wires ... nope
do a compression test every month... nope
changed turbo ... nope
intercooler ... nope
all piping... nope
one thing i havn't touched since the rebuild way way back in 2000... the fuel pump... you should try it... i'm just too lazy... maybe something in the fuel pump...
HOK is offline   Reply With Quote
Old 12-06-2002, 09:17 PM   #14
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Well, something that's been known to happen on cars with a vacuum line to the map like the link.... Some water condenses and freezes in the line, causeing a total or partial blockage. This could screw a lot up and would appear suddenly. Do your map readings react quickly and seem right?
Midwayman is offline   Reply With Quote
Old 12-06-2002, 09:24 PM   #15
Darshu
Member#: 1676
98RS w/ EJ257/Dom
Actually it sounds like a vacuum leak. Did you check all your vacuum lines? Are you venting your BOV to atmosphere? If so, do you think it could be leaking? Are your readings from your MAP sensor normal? Just throwing more questions out there....
Old 12-07-2002, 02:36 PM   #16
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Problem solved. I don't know exactly how, but the plugs were fowling. There's a nice carbon streak running down the side of a plug. It wasn't there yesterday, but it's very evident today. I did change out the plugs but maybe they weren't getting seated correctly. I feel that this is part of a bigger problem. I'll have to be on the lookout to make sure it doesn't keep happening.
Old 12-07-2002, 03:53 PM   #17
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
still running rich?
Maybe you should consider running in closed loop. Subarus run with a wideband O2 sensor for a reason. They have great response and high resolution. A properly tuned engine would have less carbon in the cylinders too. Assuming that the carbon is from gas and not oil.
Are you running an oil catch can? These are always a good idea on turbocharged motors.
Old 12-08-2002, 12:56 PM   #18
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
It happened again, sigh. It was/is the #3 plug fowling up.
This morning I was going to leave but the car wouldn't start. I loaded up the laptop and noticed that the ignition type was set to single coil. This has happened before in the past and for the life of me I can't figure out how it gets set to that. I set it back to dual and the car started and idled fine. I drove about 150 feet and the car starting missing again, idling and driving very rough. I came back home and check the #3 plug and it is completely soaked with fuel. I am going to go try another plug and see what happens.
How in the world is this happening. Something wrong with the Link?
Old 12-08-2002, 01:15 PM   #19
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Put in a new plug and and it fouled in about 15 seconds. An injector is getting stuck open or receiving a constant signal from the Link is my only guess.
Old 12-08-2002, 01:48 PM   #20
Darshu
Member#: 1676
98RS w/ EJ257/Dom
Are you sure your plug wire on cyl 3 isn't bad? Did you measure the resistance of your injectors?
Old 12-08-2002, 02:14 PM   #21
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
Swap spark plug wires and see if it changes. That's an easy troubleshooting tool. If it follows the plug wire then there's your problem. If it stays on number three, check your injector.
Old 12-08-2002, 07:46 PM   #22
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Okay, I tried a friend's plug wires, again. #3 plug wire is the problem, but only when it's humid outside. The whole thing started when it was really cold and wet a few days ago. The plug wire couldn't give enough juice to the plug and the plug then got carbon deposits all over it from the fuel not being burnt. So, when the weather cleared up and I changed the plug everything worked. Today is is rainy here so the problem arose again.
Hopefully this will also clear up the hesitation I couldn't tune out at WOT in all gears. If so, I'll finally hit my 230whp mark I have been shooting for.
Old 12-08-2002, 09:14 PM   #23
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
Congrats!
You going to get some nice Magnecore wires?
Old 12-08-2002, 09:17 PM   #24
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I found some Magnecor KV85 wires at Alamo Motorsports for 80 bucks. Is that a good deal?
Old 12-09-2002, 03:52 AM   #25
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
hell yes!
I paid almost 125 for mine a year ago!
Buy them direct from magnecore with a month wait for 90 bucks
Broken Motorsports has GC SPECIFIC Rally Armor Mudflaps and other models as well Broken Motorsports Exterior/Styling 0 02-18-2009 01:33 PM
wtt: my 5zigen super sixs and wtb parts as well midnight2.5rs-t MWSOC Private Classifieds 16 09-28-2008 11:30 PM
P0301 Misfires - Rough Idle as well jputnam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-14-2008 09:46 PM
FS: 12 Subs and Amp. Camera as well. Crash477 Private 'For Sale' Classifieds 2 09-28-2004 10:38 AM
A follow up on my compression questions and the answers as well.... Fitz Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-03-2001 02:14 PM
