Old 12-07-2002, 04:52 PM   #1
RACe
Member#: 28390
'03 WRX Sedan
MBP
Default OEM Turbo Gauge Light
Does anyone know the fix for the OEM Turbo Gauge Light being white instead of greenish, like the other dash lights? I searched the old threads, and found TrippKnight's question from May, but could not find an answer.
RACe is offline   Reply With Quote
Old 12-07-2002, 05:10 PM   #2
mlambert
Member#: 13831
the only fix i know of is getting a different gauge, neat huh?
mlambert is offline   Reply With Quote
Old 12-07-2002, 06:22 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Is the bulb accessible from the back of the gauge? On my Omori gauge, you remove a sticker on the back of the gauge, and the bulbs unscrew - if you can replace the bulb, see if you can find a green bulb cover/condom or a bulb with green glass...
Old 12-07-2002, 06:33 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not sure if you are saying whether you want it to be white or green, but you may find some helpful info here:
http://forums.nasioc.com/forums/show...hreadid=132290
Since doing the lighting mod described in the linked thread I can actually read the boost gauge at night, before it was only usable in the daylight.
Old 12-08-2002, 06:01 AM   #5
RACe
Member#: 28390
'03 WRX Sedan
MBP
Thanks. Just want the column-mounted gauge light to match the dash lights.
OEM turbo gauge install junnel20 Texas Impreza Club Forum -- TXIC 15 11-15-2004 07:50 PM
FS: Oem Turbo Gauge Pack. 3 Gauges & Pod. ptsmalls Tri-State Area Forum 0 09-03-2004 09:24 AM
turbo gauge lighting question bclee Electrical & Lighting 6 08-19-2003 11:14 PM
FS: OEM Turbo Gauge Pack 02-04 WRX Samirr76 Tri-State Area Forum 5 06-21-2003 04:06 PM
OEM Turbo Gauge Stutter? Timmay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-05-2002 09:38 PM
