Old 12-07-2002, 06:26 PM   #1
boxerT
Member#: 16311
2004 STi
WR Blue
Default Cold weather noise from the rear suspension of a WRX sedan.
I have the SPT/STi struts with STi top mounts, stock endlinks, and Cusco rear anti-roll bar set at full stiff.
Whenever the otside temperature drops below 55 degrees or so, the suspension makes loud rubbing noise (during compression)while driving over speed bumps or road humps. On a warm day the noise goes completely away.
I was experiencing this noise last winter, it went away during the summer and now it is back again.
Any ideas?
boxerT is offline   Reply With Quote
Old 12-08-2002, 06:36 PM   #2
WRX1832
Member#: 4384
02 WRX([email protected])
I know this sounds weird but press down on the rear of the trunk and listen for the crunching noise. I had a very similar issued and thought it was the suspension because it also only did it on bumps. Kind of a crunching noise. It got so bad I was concerned with driving the car, so I removed the strut for inspection.....nothing...everything was find. reinstalled and the noise was still there. Then I found it...the trunk when going over a bump will compress into the body of the car (probably worse with a spoiler because of the added weight). The noise I was getting was from the trunk latch itself. Attempted to adjust it did not work and that is when I applied white lithium grease to the latch and the part it clamps on to. Noise gone. I was amazed that was it because of how severe the noise was, but it worked.
Give it a shot before tearing apart your suspension. I cannot believe I am the only one with this problem.
Mike
Nice and quiet 02 WRX
WRX1832 is offline   Reply With Quote
Old 12-08-2002, 09:41 PM   #3
boxerT
Member#: 16311
2004 STi
WR Blue
Thanks, I will try that and let you know what happened.
Did yours do that in colder weather only?
My car does have the factory rear spoiler.
Old 12-09-2002, 04:43 PM   #4
boxerT
Member#: 16311
2004 STi
WR Blue
After applying the lithium grease, the noise did not go away completely, but was reduced substantially. Next, I will try to lubricate the trunk lid springs to see if that will help.
Thanks WRX1832!
Strange noise from the rear suspension. Zottyzot Brakes, Steering & Suspension 15 02-24-2009 03:55 PM
intermittent scraping noise from the rear end of my '02 WRX WRX Smokescreen Transmission (AT/MT) & Driveline 5 09-04-2007 06:43 PM
Suspension Knocking Noise from the Rear ComTekAuto Brakes, Steering & Suspension 6 02-15-2007 02:15 PM
Think they'll un-bundle the cold weather gear from the moonroof for '06 models? grue News & Rumors 9 03-09-2005 10:38 AM
anyone else get a popping noise from the rear suspension on hard cornering? jmott Brakes, Steering & Suspension 5 05-14-2002 12:18 PM
