Old 12-07-2002, 07:29 PM   #1
Titanium Samurai
Member#: 25296
MY99 JDM STiv6 Wagon
Sonic Blue
Question Axle stands vs. jack stands vs. axle jacks: I'm going under
Someone once posted NEVER to get under a car on a jack. Nonetheless, I've seen numerous posts that mention putting the car on 'jack stands' or 'axle jacks'. I wouldn't get under if the car was supported by tire-changing jacks, so I bought a couple of pairs of 'axle stands'. They were some fairly heavy-duty Michelin sets each rated for 3 1/2 tons. The thing that confuses me is that they -- like all the other axle 'stands' I saw -- are adjustable. The fact that they're adjustable doesn't make them unsafe for getting UNDERNEATH the car, does it?
Also, is it okay to put axle stands in the jacking points if I want access to the axles and such?
Titanium Samurai is offline   Reply With Quote
Old 12-07-2002, 09:24 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
All jack stands that I know of are adjustable. They are rated to hold specific weights with that adjustability so I wouldn't worry about it. As a precaution, I would still leave a jack in place or if you've removed the wheels for any reason, I usually leave them flat and under the edge of the car. If anything fails, knock on wood, then at least the rims will prevent the car from crushing me.
As for placement of the jack stands, I usually use the front subframe/crossmember sections and for the rear, there is a flat spot a little further in from the factory jack points that you can use. If you do use the factory jack points, I would use something like a hockey puck or a peice of wood with a slot cut in it so that you don't bend the metal tabs.
Calvin
cnk is offline   Reply With Quote
Old 12-09-2002, 11:11 PM   #3
kalex
Member#: 2070
2012 Audi S5
Brilliant black
Default Use...
Wood block or bricks behind and on front of wheels to prevent the car from rolling of the jacks or jack stands. I use a combination of Jack, jack stand and always wheel chocks.
kalex is offline   Reply With Quote
Safe to use jack stands under suspension? shotoyan Service & Maintenance 12 07-06-2006 12:18 AM
Jack stand and jack for 2005 STi Hye-Teck Newbies & FAQs 11 04-05-2005 10:22 PM
Is it Ok to put jack stands under the tow hooks? waitandbleed92 Off-Topic 9 03-13-2005 04:56 PM
need to borrow a jack and a set of jack stands please. V6TurboTA New England Impreza Club Forum -- NESIC 22 04-29-2004 03:03 PM
Jack Stands are bending the bezel under my car Kyguy General Community 2 04-01-2004 12:06 PM
